By the book......
Old Oct 5, 2002 | 01:26 PM
  #26
SilverLudeSi's Avatar
New User
Default Re: By the book...... (Inlinefour)
Just a suggestion for GE:
Since there is a decent amount of misinformation about turbo hondas out there, you should have a large FAQ section on your site. You could start off with just a few sections, covering things like head gaskets, head studs, oil pumps, proper motor break-in, piston to wall clearances, ring gaps, etc.
I'd bet many of your current and future customers would find the information very helpful, and it would keep you from having to repeat yourself over and over and over.
very good idea
Old Oct 5, 2002 | 01:42 PM
  #27
X-Mazda 3 Racer's Avatar
Thanks for the advice, and I have already made a few FAQ pages for the new site which will be up very shortly! Thanks guys
Old Oct 5, 2002 | 01:48 PM
  #28
Midwestrider's Avatar
Default Re: By the book...... (V8KILR)
Thx for the info..
Old Oct 5, 2002 | 02:04 PM
  #29
SiRkid's Avatar
I suggested a FAQ first!
Old Oct 5, 2002 | 09:43 PM
  #30
paulzy's Avatar
Default Re: By the book...... (SiRkid)
I suggest every turbo honda owner to get rid of AC hahahaha
Don't flame me for this, but somehow, everyone that everyone who wants a turbo kit for their honda wants 450whp with very cold AC to drive back and forth from alaska to mexico
Old Oct 5, 2002 | 11:46 PM
  #31
Flamenco-T's Avatar
Default Re: By the book...... (paul_vang)
so, are we confirm on 82 ft/lbs of torque ? I am sensing a lil headgasket leak due to mis-torque on the studs...Coincidentaly, I am planningon doing it tmw....
Old Oct 7, 2002 | 12:29 PM
  #32
internet ay's Avatar
Default Re: By the book...... (Flamenco-NA)
what kind of leak are you getting?
Old Oct 7, 2002 | 12:39 PM
  #33
VaporTrail's Avatar
New User
Default Re: By the book...... (Boosted99Si)
True true about ARP, me and some friends called all with GE blocks and ARP head studs, they advise to torque the studs to 70lb-ft then go through 10 yes 10 heat cycles of starting the motor and getting it up to operating temps then letting it cool down for 30 minutes then again. After the heat cycles retorque each stud by loosening one at a time then retoquing with 5 ft-lbs more 75 lb-ft total. This is the latest. I've talked to you Vince and can only imagine the calls you get I called last week and talked to you. Thanks for coming on the board and actually backing your product and providing tech assistance after the sale. Sorry if I've bugged you. me then.
Can someone please verify this (such as Viren or vaportrail). Ive got about 1100 miles on my GE block with ARP studs and they are torqued at 70. I never went back and re torqued them after 10 warm up periods. This is the first I have ever heard of this. So please some of the really experienced honda techs on here please post your opinions.
I do recommend retightening after 1000 miles, or on a race motor, 10-20 heat cycles. I also recommend not installing the studs finger tight, rather putting them in, double nutting them, hand tight, then 1/4 to 3/8 of a turn with a wrench, not to exceed 10ft/lbs of torque. But thats just me, others will disagree, some will agree.
Old Oct 7, 2002 | 02:41 PM
  #34
Boost2NA's Avatar
Default Re: By the book...... (VaporTrail)
thanks for the reply..............guess i gotta pull the cams and retorque them.
Old Oct 7, 2002 | 03:14 PM
  #35
2000Accord5sp's Avatar
If Vince says ARP studs only hold 340~ hp, why would they recommend ARP studs with their blocks when obviously a lot of folks that get GE sleeved blocks is to have way more than 340hp...just curious...
Old Oct 7, 2002 | 03:32 PM
  #36
Default Re: By the book...... (2000Accord5sp)
Do you know of any other stud company that makes headstuds for Honda? I know of one and they are working with a competitor of mine. I am currently working with ARP to try to get some new materials in some headstuds that I can provide to you the consumers. Although the ARP's are only rated at about 350 - 400 HP, they are still better than stock!!! P.S., loose the sarcasm!!
Old Oct 7, 2002 | 03:41 PM
  #37
No, no sarcasm...just making sure that was the case. So pretty much ARP is all we can rely on for now and hope they hold...hmm...and what about the torqing mentioned by someone here that you recommend 82lbs? Is that true? Just making sure you confirm that.
Thanks for the info!
Old Oct 9, 2002 | 08:24 AM
  #38
CivicT
Oct 25, 2004 08:29 PM
oMek
Oct 17, 2003 01:21 PM
Drew Peacock
Feb 7, 2003 12:32 AM
GQ Cowboy
16
Jun 27, 2002 03:21 PM
LsTurbo91
May 2, 2002 05:17 AM
