Bolt grade?
Old Jul 31, 2007 | 08:01 PM
almostboostedgsr's Avatar
Default Bolt grade?
Yep I searched. I know the exact size im going to need for my bolts that connect the turbo to the manifold.
Im just trying to figure out what grade of bolts do you guys use. I think grade 8 strenght should work.
Any sugguestions?
Old Jul 31, 2007 | 08:15 PM
Default Re: Bolt grade? (almostboostedgsr)
bump
Old Jul 31, 2007 | 08:23 PM
Muckman's Avatar
Moderator in Chief
Are you talking grade 8 US or 8.8 Metric?
Old Jul 31, 2007 | 08:27 PM
Default Re: Bolt grade? (Muckman)
I wrote this post right after I got off the phone with my dad. He just told me grade 8.
Heres my specs, 10mmx1.25 (30mm)
Old Jul 31, 2007 | 08:58 PM
Muckman's Avatar
Moderator in Chief
That would be 8.8 technically. Heres some specs for you:
http://www.boltdepot.com/faste....aspx
Im sure 8.8 would be fine but considering the weight and extreme thermal expansion Id go with grade 10.9
Old Jul 31, 2007 | 09:13 PM
Yeah 10.9 it is.
Can I use the same grade for the down pipe bolts aswell?
Old Jul 31, 2007 | 09:15 PM
tony413's Avatar
all the bolts on the engine and tranny stock are grade 8.8
Old Jul 31, 2007 | 10:12 PM
LeGeND4LiFe's Avatar
Default Re: (tony413)
The A2 stainless bolts look like they would work well.
Old Aug 1, 2007 | 04:26 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">Yeah 10.9 it is.
Can I use the same grade for the down pipe bolts aswell? </TD></TR></TABLE>
of course. the stronger, the better. you can never go wrong with an overkill bolt.
dinko
Suspension & Brakes
10
Jan 18, 2008 09:07 AM
mrrugsr
Mar 1, 2006 07:55 PM
mrrugsr
Mar 1, 2006 08:00 AM
servion
Mar 5, 2005 02:05 PM
