bolt doesn't fit in manifold... WHAT TO DO?
Old Jun 14, 2004 | 12:17 AM
tyflip2's Avatar
Default bolt doesn't fit in manifold... WHAT TO DO?
hey i was just installing my manifold and realized that the top left bolt does not fit because the runner is in the way. it is a tubular manifold and the runner doesn't allow enough room to fit the bolt in there. would it be a bad idea to not run with this bolt in. any suggestions? thanks alot for any help
Old Jun 14, 2004 | 12:26 AM
project dc2's Avatar
Default Re: bolt doesn't fit in manifold... WHAT TO DO? (tyflip2)
use studs and nuts. pull the manifold out and thread th stud ad thread as you push the manifold in.
Old Jun 14, 2004 | 01:32 PM
tyflip2's Avatar
Default Re: bolt doesn't fit in manifold... WHAT TO DO? (project dc2)
would it be bad to not put that one bolt in. would there be a leak?
Old Jun 14, 2004 | 01:53 PM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">would it be bad to not put that one bolt in. would there be a leak?</TD></TR></TABLE>
most likly
Old Jun 14, 2004 | 02:44 PM
alpha's Avatar
https://honda-tech.com/zerothread?id=874030
Old Jun 14, 2004 | 03:36 PM
Boltz's Avatar
Default Re: bolt doesn't fit in manifold... WHAT TO DO? (0x64)
Although you've provided little information for us to help you with, it sounds like bad craftsmanship/poor manifold
Old Jun 14, 2004 | 04:26 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> use studs and nuts. pull the manifold out and thread th stud ad thread as you push the manifold in. </TD></TR></TABLE>
exactly^. I'm not saying this to be a *****, but I can't beleive how many people can't figure this out without posting on here. logic is a bitch i guess
Old Jun 14, 2004 | 04:33 PM
.dave's Avatar
i HAS questions ?
Default Re: bolt doesn't fit in manifold... WHAT TO DO? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">
exactly^. I'm not saying this to be a *****, but I can't beleive how many people can't figure this out without posting on here. logic is a bitch i guess</TD></TR></TABLE>
My Drag manifold is a huge pain in the ***. There are 3 bolts that you have to just keep threading and inching the manifold on, all the others are fine though.
Old Jun 15, 2004 | 11:40 PM
tyflip2's Avatar
Default Re: bolt doesn't fit in manifold... WHAT TO DO? (dtmamg)
the problem is that there is no room to turn the bolt once the stud is through the manifold. the stud sits too close to the manifold. it is the top left bolt on the manifold. i tightened all the other bolts, do you think it will be a noticable leak??
Old Jun 16, 2004 | 09:36 AM
tyflip2's Avatar
up!
Old Jun 16, 2004 | 09:54 AM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyflip2 &raquo;</TD></TR><TR><TD CLASS="quote">the problem is that there is no room to turn the bolt once the stud is through the manifold. the stud sits too close to the manifold. it is the top left bolt on the manifold. i tightened all the other bolts, do you think it will be a noticable leak??</TD></TR></TABLE>
yes
Old Jun 16, 2004 | 12:19 PM
dustin's Avatar
definitely
tegh22a
Aug 26, 2005 09:22 AM
nojoke
Feb 12, 2005 05:23 PM
GDM Z28
Jan 21, 2004 12:12 PM
Stu
Jan 15, 2004 01:19 PM
