bogging at 1-2 psi
Old Nov 13, 2001 | 05:03 PM
sagaprelude's Avatar
Default bogging at 1-2 psi
when i drive normal, as soon as my boost kicks in, the whole car jus heisitates, then kicks real hard, whats goin on? im thinkin its a blown head gasket because i think im suffering from head gasket symptoms TIA
Old Nov 13, 2001 | 05:05 PM
GSRwBOOST's Avatar
Default Re: bogging at 1-2 psi (sagaprelude)
do you have the missing link and if so is it clogged?
throwing any codes?
i had a similar problem when using the check valves...
Old Nov 14, 2001 | 09:11 AM
Default Re: bogging at 1-2 psi (GSRwBOOST)
i have the missing link, ill throw a code 72 every once in a while
Old Nov 14, 2001 | 11:29 AM
jbsadler's Avatar
New User
Have you checked out your FMU.......
(happened to flamenco-t)
Old Nov 14, 2001 | 02:52 PM
Flamenco-T's Avatar
72 cylinder 2 misfires, it happened to me, all four cylinders misfires, it turned out that I have a defective FMU, the FMU stays wide open at idle and vaccum, so practically dumping all fuel to the cylinders from teh pump.
replaced my fmu last night and no more bogging or CEl...
might want to check your FMU...
Old Nov 15, 2001 | 01:39 AM
paulzy's Avatar
Default Re: bogging at 1-2 psi (Flamenco-T)
yeap, same thing happened to us too, too much fuel. Turned it down and it did wonders
b18bteg14
Dec 10, 2006 02:46 PM
raysjdmh22a
Mar 17, 2006 07:01 PM
uneekcrx
Apr 26, 2002 08:16 AM
