Blue smoke at idle?
Old Jun 2, 2004 | 06:00 PM
drvfast's Avatar
Default Blue smoke at idle?
Just a few days ago my car start smoking a blue/white color. I did a compression check and the compression test resulted 220 across the board wet and dry. It only smokes after I have been driving, and let the car idle down. It smoke for 2mins or so and stops. I think it is my oil return line because it does not come striaght down to the oil pan it has a slight bend. If i keep my oil return like this will it eventually blow my turbo seals. I am not burning oil but, I do smell oil when it smokes from the exhaust. Thanks
Old Jun 2, 2004 | 06:03 PM
Vtec92Civic's Avatar
Default Re: Blue smoke at idle? (drvfast)
well generally blue is a automatic sign of of oil being burnt up some place . . . . so check any place for oil leaks etc . . .
Old Jun 2, 2004 | 06:11 PM
drvfast's Avatar
Default Re: Blue smoke at idle? (Vtec92Civic)
I did check for oil leaks. I did not see any at all. My seals could have already blown out. It shouldn't have it is a brand new sc61
Old Jun 2, 2004 | 06:14 PM
chirp3rd's Avatar
im having the same problem you are anyone else have any input on this
Old Jun 2, 2004 | 06:21 PM
Trance minister's Avatar
Default Re: Blue smoke at idle? (chirp3rd)
Definately keep an eye on that oil return. Same **** happened to my setup and then I went out one night driving and noticed I was leaving some nice smoke trails behind me... I changed the oil return line but by that time it was too late. the turbo seals were shot.
Old Jun 2, 2004 | 06:31 PM
drvfast's Avatar
Default Re: Blue smoke at idle? (Trance minister)
Thats what I am thinking also. I am going to change the oil return but I think it is too late.
peel17
Feb 1, 2005 11:28 AM
vxnine
18
Oct 11, 2003 07:24 PM
navin
18
Jun 18, 2003 01:44 PM
Boostless97Lude
Feb 1, 2003 08:44 PM
turbo_civic
Feb 1, 2003 07:36 PM
