Blue smoke!!!
Old Nov 15, 2003 | 12:57 PM
GENERAL LEE
Guest
Posts: n/a
Default Blue smoke!!!
My car has a built B18C1 with Wiseco endyn pistons, Bored by GE to 84.5mm, eacgle rods, new bearings etc. So my question is How long does it take for the rings to seat and the car to stop smoking? It only smokes when you rev it up a little bit. Not a lot but enough that you can see. It has about 60 miles on it now and I want to see if it is gonna stop. I am running 5-30 Royal purple oil. Does anything think that maybe the oil is to thin?
Old Nov 15, 2003 | 02:03 PM
99B16Si's Avatar
Default Re: Blue smoke!!! (GENERAL LEE)
i hope youre not using synthetic. also rings can take a few hundred miles to fully seat themselves. i wouldnt worry too much, its normal to smoke a tad after a rebuild
Old Nov 15, 2003 | 02:50 PM
b16ahybrid's Avatar
Default Re: Blue smoke!!! (99B16Si)
They are generally seated after the initial warm-up, after that they are basically just wearing in (forming to their new home).....you probably shouldn't be smoking by now. How have you been breaking them in?
Old Nov 15, 2003 | 03:02 PM
Foozball26's Avatar
Default Re: Blue smoke!!! (b16ahybrid)
rings seat in the first few minutes of intial start-up about 15 mins or so.
although with such tight tolerances as imports run they could seat even faster.
you definitley have something wrong, and synthetic oil is too "slick" to use in a new motor and it is blowing by the rings and thats most likely where your blue smoke is comming from.
Old Nov 15, 2003 | 03:08 PM
Chillinit's Avatar
99B16Si..why not use synthetic oil on a rebuilt motor?? The general idea is, if you use synthetic, you should alway stick with synthetic(don't switch back and fourth). Is there some sort of advantage to using regular engine oil when breaking in a motor?? do u want more wear to occur during this period?? I thought using synthetic from the get go would be a good thing?? explain please.....
Old Nov 15, 2003 | 03:16 PM
boosted hybrid's Avatar
Default Re: Blue smoke!!! (Chillinit)
Synthethic has alot of detergents in the oil. On fresh bearing surfaces the detergents at the molecular level wear themselves into the bearings. You'll experience a faster wear on the bearings. The best oil to use for break-in is non-detergent conventional oil. I have used Shell SAE 30 ND for the last few engines that I have broken in, but pretty much any brand ND (non-detergent) oil will work.
Old Nov 16, 2003 | 07:34 AM
99B16Si's Avatar
Default Re: Blue smoke!!! (boosted hybrid)
what he said
Old Nov 16, 2003 | 09:50 AM
Chillinit's Avatar
u couldn't have made it any clearer!! thanks....one more thing ....when would it be safe to start using synthetic?? 5000 km...more.... less?
92teginsc
Aug 4, 2008 11:08 AM
hailchristian
42
May 30, 2008 04:20 PM
V8 BAIT
Jul 14, 2004 03:56 AM
gregv
Mar 3, 2004 05:43 PM
crxfanatic
Jul 26, 2002 03:18 AM
