blox cast b series turbo manifold with a mishimoto full size rad in a integra
will a blox turbo manifold fit in my 95 integra with no a/c if I'm running a full size mishimoto radiator and fan shroud or if the fan shroud doesn't fit just 2 12" slim fans? I've heard that I might have clearance issues between the rad and the manifold is that true? and I'm looking for somebody has tried it not just that doesn't think it will work
Re: blox cast b series turbo manifold with a mishimoto full size rad in a integra
fullsize is fine. fan shroud is a big maybe.
make sure your turbo is a garrett or precision with a 5-bolt downpipe flanged turbine outlet ( no ebay, no XYZ bs turbos) or it wont even go on the block
I'm going to be running a turbonetics t3/t4 with a 4 bolt downpipe i shouldnt have a problem with that right?
your turbos gonna hit the block and you cant possibly grind/notch out enough for it to physically fit before you grind into the water jacket.
4 bolts are more " tanginal" than 5-bolt counterparts. which is what 95% of cast manifolds for hondas are built to fit ( 5 bolt turbos)
I ran a garrett t3/t4 57 trim with 5 bolt discharge with a PWR full size radiator on a blox cast manifold; with fully functional a/c and power steering... passenger side shroud was fine but had to run a slimfan on the drivers side. very tight fit but it was doable and never gave me any issues...
hmm well my 4 bolt clears the block fine it might be cause my downpipe comes out the passenger side? heres a few pics of it now shaving needed
i bought mine from full-race... im not sure if they carry them anymore but thats a start, also i ran the turbo flipped the other way- compressor facing the passenger side, dp coming out on drivers...
nuckingfuts
08-06-2007 05:31 PM
91crxturbo
05-23-2007 02:30 PM
