Blowoff in neutral?
Old Apr 11, 2003 | 03:38 PM
  #26
boostsohfast's Avatar
Default Re: Blowoff in neutral? (InfamousRS)
I can get my type-s to blow off in neutral with my small 15g on the greddy kit. It's no where near as loud as when I drive though.
Old Apr 11, 2003 | 04:14 PM
  #27
Foozball26's Avatar
Default Re: Blowoff in neutral? (boostsohfast)
My t3/to4e and hks ss blow off a little if i rev to like 4k, Im not building boost but the BOV opens when the throttle plate closes so I get a little psst of air.
Nothing crazy like 15 psi
Old Apr 11, 2003 | 04:17 PM
  #28
yellowhonda88's Avatar
indeed, with a small *** 15g hairdryer, it will do it all day...lol. But i have seen it happen several times on a honda. I think all of them are 1.8 l and above though.
Brett
Old Apr 11, 2003 | 05:36 PM
  #29
safe driver's Avatar
Default Re: Blowoff in neutral? (yellowhonda88)
I have an t3/to4e 60trim .60a/r with a stg3 .63a/r turbine on my h22a4 and i can blow-off in neutral.
Old Apr 11, 2003 | 05:50 PM
  #30
Ben Huynh's Avatar
Default Re: Blowoff in neutral? (safe driver)
This is one of those mysterious quirks in life. Some setups do, some don't.
Old Apr 11, 2003 | 06:10 PM
  #31
MiraiZ's Avatar
Default Re: Blowoff in neutral? (ben@importparts.com)
I believe it got a lot to do with compression as well. I don't know about now, because I don't dare to reve my engine past 4000rpms while its breaking in, but when I had stock pistons (cr 11:1) I was able build boost in neutral with a t3/t4 .63 a/r. And the turbine was always spinning, even at idle. I haven't checked to see if the turbine spins now with 9:1 cr though.
I also have thermal wrap on my header which I heard helps a bit too...
Old Apr 11, 2003 | 06:21 PM
  #32
-=-'s Avatar
Default Re: Blowoff in neutral? (MiraiZ)
So I guess it will be hard to blow off to a chick crossin the street huh lol j/p
Old Apr 11, 2003 | 08:54 PM
  #33
FredoSP's Avatar
Default Re: Blowoff in neutral? (-=-)
maybe its as simple as the adjustment for the BOV, I know with my Type S u can adjust the nut soft/hard; i can blow off in Neutral, but its very faint (18G).
Old Apr 12, 2003 | 06:23 AM
  #34
johnisenglish's Avatar
I've got a 60trim T3 on my B18b1 and I can blow off in neutral if I rev up past 5000rpm or so
Old Apr 12, 2003 | 06:35 AM
  #35
JDM EG2's Avatar
Default Re: Blowoff in neutral? (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">then most likely he dont have a t3/t4. He probobly lied to you. Ask anyone on the board and they will tell you that turbo will not spool in neutral. </TD></TR></TABLE>
The car in my sig blows off with no load but after like 6500rpm and like 1/3 as loud as if driving it.
Old Apr 12, 2003 | 07:23 AM
  #36
TeStUdO's Avatar
Default Re: Blowoff in neutral? (TurboB16Coupe)
we put the turbo xr rfl BOV on my buddy's volvo c70 and he can blow off big time in neutral. its also a 5 cylinder though, and a 16g turbo
Old Apr 12, 2003 | 09:12 AM
  #37
boostedsol's Avatar
Default Re: Blowoff in neutral? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">it's not gonna happen, your turbo is prolly too big and smaller displacement, not enough to drive the turbine...
sell your honda and get a DSM's if you wanna show it off
stan</TD></TR></TABLE>
Yup.
Old Apr 12, 2003 | 11:28 AM
  #38
UberTeg's Avatar
Default Re: Blowoff in neutral? (boostedsol)
I can blow off with my t25 b18a. It reaches about 6psi in nuetral.
Old Apr 13, 2003 | 09:34 PM
  #39
T3T495GSR's Avatar
mine does it after 7krpm in neutral
Old Apr 13, 2003 | 09:46 PM
  #40
turbod16y8's Avatar
Default Re: Blowoff in neutral? (T3T495GSR)
my 14b turbo on my sohc blows off in nutrual.... pretty damn loud too
Old Apr 14, 2003 | 05:12 AM
  #41
boostin GSR's Avatar
Default Re: Blowoff in neutral? (Andrew 825SM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM &raquo;</TD></TR><TR><TD CLASS="quote">I have a 18G and my car can blow off when you rev it to 6 grand. My bov blows off when the vacuum is close to 0 psi. </TD></TR></TABLE>
me too, i dont boost, it just blows off
Old Apr 14, 2003 | 06:12 AM
  #42
MiraiZ's Avatar
Default Re: Blowoff in neutral? (BoostinGSR)
You may also want to try the HKS racing BOV...it works a bit differently than the other BOV's in that it is always open when the throttle plate is closed. So even at idle the BOV is open. Makes for a better exit for excess boost pressure when not needed and absolutely no surge. So my car always blows off even at low revs.
C_H_A_D
May 15, 2006 06:15 PM
iBrandon
Sep 2, 2004 01:25 AM
JunIntegra
Oct 5, 2003 02:13 PM
^MikeG
Sep 27, 2003 03:36 AM
td04civic
Feb 12, 2002 08:36 PM
