blown engine @ 5psi ?
Old May 12, 2003 | 07:20 AM
Sinner's Avatar
Default blown engine @ 5psi ?
I got a loud knock around 2,500, but it idles fine. What have I destroied :-). from I might have found an answer, but I just wanted to see if yall think the same thing.
Nick
Old May 12, 2003 | 07:40 AM
Adi Radoncic's Avatar
On Fire!
Default Re: blown engine @ 5psi ? (Sinner)
Is the noise coming from the bottom of the enigne more than the top?
I'm not a 100% sure on this but my guess would be from what your saying its probalby a spun bearing..
Adi
Old May 12, 2003 | 07:42 AM
Sinner's Avatar
yup it seems t be comming from the bottom and spun bearing is what I figured it was. Is it worth to fix or just replace? I got a d15y7 block in storage. I wonder how well it would do with my d16y8(current motor) head and some turbo.
Nick
T-sohctec's Avatar
why do you think the engine is blown?
I re-read the post, I thought you had a single knock at 2,500 and that was it.
if it sounds like a loud valve tap then I would concur, spun bearing.
Old May 12, 2003 | 07:44 AM
Sinner's Avatar
to fix or to replace.. that is the question. I will be doing all the work.
Old May 12, 2003 | 08:54 AM
On Fire!
Default Re: (Sinner)
If you already have it in storage why spend money on machine work and all of that if your main concirn is to just get the car to a good runing condition..
I would say just drop the other block in and worry about fixing or building up the other one later on...
Adi
amtrak23
Oct 27, 2015 07:49 AM
jhammond_82
Oct 16, 2009 10:53 AM
jdm-spec-eg
Apr 1, 2003 02:31 PM
Xlerate9
Mar 28, 2003 02:34 PM
alopez84
Mar 28, 2003 01:11 PM
