Blowing out spark!!!!
Old Aug 18, 2007 | 11:57 AM
92redhatch's Avatar
Default Blowing out spark!!!! HELPPPP
it wasnt blowing out spark
Modified by 92redhatch at 9:01 PM 2/21/2008
Old Aug 18, 2007 | 12:02 PM
iTz On!!!'s Avatar
Default Re: Blowing out spark!!!! (92redhatch)
seems like your having the same problem I am.
https://honda-tech.com/zerothread?id=2072079
Old Aug 18, 2007 | 12:05 PM
92redhatch's Avatar
on 8 psi i made 220whp and it looked kinda like your graph but after we raised the boost it would break up and lose a lot of power.
Old Aug 18, 2007 | 12:06 PM
iTz On!!!'s Avatar
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">on 8 psi i made 220whp and it looked kinda like your graph but after we raised the boost it would break up and lose a lot of power.</TD></TR></TABLE>
yeap exact problem i have...
Old Aug 18, 2007 | 12:07 PM
92redhatch's Avatar
what did your tuner say your problem was?
Old Aug 18, 2007 | 12:26 PM
92redhatch's Avatar
anyone have any opinions on what my problem can be?
Old Aug 18, 2007 | 12:51 PM
quicksilver1689's Avatar
i ♥ snails
that downpipe is going to hinder alot of power in the higherboost levels.
I would stay away from the msd ignition box, an external coil might be a good idea , give you dizzy a little check over, make sure the ignitor and coil are still working good, if you get a multimeter and a manual you can check the resistance and make sure there still in spec. What did you gap the plugs down too?
Old Aug 18, 2007 | 02:04 PM
92redhatch's Avatar
we gaped down the plugs to 18. we had them at 25. we checked the distributer and everything is working fine. i havent checked with a multimeter yet.
i had problems with my last msd box. but im going to try another new one and see what happens.
Old Aug 18, 2007 | 02:05 PM
92redhatch's Avatar
i know i need a bigger downpipe. but for the meantime i want to get the car to make decent power the way it is.
Old Aug 18, 2007 | 02:52 PM
92redhatch's Avatar
bump
Old Aug 18, 2007 | 03:04 PM
RACEPAK's Avatar
oem coil/igniter?
Old Aug 18, 2007 | 03:16 PM
92redhatch's Avatar
yes i have on my car an oem coil and oem ignitor and oem spark plug wires and oem cap and rotor.
Old Aug 18, 2007 | 04:50 PM
92redhatch's Avatar
http://www.youtube.com/watch?v=-wEhmdWqMD0
Old Aug 18, 2007 | 05:23 PM
92redhatch's Avatar
i added a video of one of the dyno runs/
Old Aug 19, 2007 | 12:36 AM
jonvo's Avatar
make sure you have a good ground to the valve cover. that was the cause of my spark blowing out.
Old Aug 19, 2007 | 07:08 AM
92redhatch's Avatar
its funny because i was thinking about adding a grounding kit. right now i just have the factory grounds.
Old Aug 19, 2007 | 07:10 AM
RACEPAK's Avatar
Default Re: (jonvo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonvo &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have a good ground to the valve cover. that was the cause of my spark blowing out.</TD></TR></TABLE>
:S:S really?
Old Aug 19, 2007 | 10:21 AM
92redhatch's Avatar
i dont think ima spend the money on a aftermarket grounding kit. anyone else have an idea on what it could be?
Old Aug 19, 2007 | 11:17 AM
ebrow21's Avatar
What are your afr's. I am running 28 on 7e's (stock ignition) at 10.5lbs and if I run anything richer than 11.3:1 or so it will do the same. Runs perfect otherwise.
Also, why aren't you running 7e's?
Old Aug 19, 2007 | 11:55 AM
92redhatch's Avatar
im running 8's because the goal on 118octane was 500whp.
and on 93 oct 400whp.
my a/f ratio was always between 11.5-12.0 until it started to blow out spark.
on 8psi it made very little power but didnt blow out spark and on 14psi it blew out the spark.
Old Aug 19, 2007 | 12:28 PM
92redhatch's Avatar
http://www.youtube.com/watch?v=qjc63I0vHtU
heres another video of the dyno
Old Aug 19, 2007 | 06:58 PM
92redhatch's Avatar
in that last video you can see when it blows out spark
Old Aug 19, 2007 | 07:35 PM
Jaker's Avatar
I had very similar problems with my D series with M62 Endyn blower kit. I was running about 14-15 psi and the engine was missing like you describe. I tried many different things, like smaller gap, etc... but nothing fixed the problem till I wired in the MSD-6AL. I wired it up to the OEM coil, and was already using Magnecore 8.5mm wires with heat range 7 plugs. Once the MSD went in, the miss was totally gone. Period. I was even able to take the boost up to 22psi, open up the gap some, run heat range 8 plugs, and still no miss.
Old Aug 19, 2007 | 07:47 PM
92redhatch's Avatar
great i hope by installing an msd it will fix my problem also.
Old Aug 20, 2007 | 08:03 AM
RACEPAK's Avatar
dont forget to let us know...
