blockguard yes or no
Old May 1, 2008 | 05:37 PM
95_red_dc's Avatar
Default blockguard yes or no
I have a 95 gsr b18c1 I spun a bearing and in middle of rebuilding it for turbo later on down the road. I plain on using 9.1 cp pistons, eagle rods. I heard good things and bad things about blockguards. I talked to my machine shop and they said they have installed them before with no problems. I know you tap them in to just below deck height before you have the block bored. Are they suppose to be tac welded in? My horsepower goal is around 400-450 with a good tune. So is a blockguard needed for extra security?
Old May 1, 2008 | 05:39 PM
RedneckRicer's Avatar
not worth it imo. seen several 450-500 whp on stock sleeves and no block guard so money could be spent else where
Old May 1, 2008 | 06:12 PM
peakaboost's Avatar
Default Re: (RedneckRicer)
NO DEFINATLY NOT.....
People may argue,but blockguards 1,create "hotspots" on cylinder walls potentially creating detonation. 2 cylinder walls see the greatest amout of stress between the middle and bottom of the cylinder NOT the top,and 3 restrict coolant flow to the head (goes along with number 1),and finally 4,they put uneven pressure on the top of the sleeve that can create an oval,or egg shaped deformity.
simply put....no,your better without one.
Old May 1, 2008 | 06:27 PM
95_red_dc's Avatar
Default Re: blockguard yes or no (95_red_dc)
So no blockguard for my build thanks
Old May 1, 2008 | 06:50 PM
Schister66's Avatar
Man U FTW
You're going to get a resounding "NO" from most everyone who knows anything about turbo Hondas. They're merely for peace of mind. The sleeves are going to crack with or without a block guard. The only way to prevent that is with aftermarket sleeving.
Old May 1, 2008 | 07:24 PM
ONE*SICK*FERIO's Avatar
NO
save it for some aftermarket sleeves
Old May 1, 2008 | 07:44 PM
joe111599's Avatar
dont need it...waste of money.
Old May 1, 2008 | 07:56 PM
FastEg6's Avatar
Yes, like everyone is stated, no need for it. Rather run stock sleeves without the guard then with it. Like peakaboost said, it'll create all those things that was stated...save the money spend on something that'll help.
Old May 2, 2008 | 05:42 AM
Jvs10's Avatar
Default Re: (FastEg6)
You could even try posting your block which would give the cylinders extra support in the middle where they need it the most. No, I wont tell you how its done, google is your friend
Old May 2, 2008 | 03:41 PM
95_red_dc's Avatar
Thanks everone for there replys
Old May 3, 2008 | 09:10 AM
boost4life's Avatar
id install one i made 375 on 14lbs and my sleeve went to another dimesion and it was tuned by rlz so it had a semi decent tune a block gaurd will help your sleeve from taking out your entire motor
Old May 9, 2008 | 12:42 AM
joe111599's Avatar
Default Re: (boost4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost4life &raquo;</TD></TR><TR><TD CLASS="quote">id install one i made 375 on 14lbs and my sleeve went to another dimesion and it was tuned by rlz so it had a semi decent tune a block gaurd will help your sleeve from taking out your entire motor</TD></TR></TABLE>
dont need it
95gsrturbo
Oct 9, 2010 04:55 PM
jeremy
Oct 20, 2009 05:18 PM
SMOOTH97LUDE
Mar 10, 2004 10:53 PM
rexinfection
Nov 15, 2002 06:53 AM
Wicked Sol
May 11, 2002 04:36 PM
