block guard for a zc??
Old 12-18-2001, 01:36 PM
zexdrex's Avatar
Default block guard for a zc??
what block guard would i use for a ZC ??????????
Old 12-18-2001, 01:48 PM
New User
01geeser's Avatar
Default Re: block guard for a zc?? (zexdrex)
d-series
Old 12-18-2001, 05:40 PM
Denny317's Avatar
Default Re: block guard for a zc?? (01geeser)
The STR D-series blockguard that I originally bought for my ZC didn't fit...go figure
Old 12-18-2001, 10:24 PM
greyzone's Avatar
Default Re: block guard for a zc?? (No Boost)
When in doubt call the manufacturer...talk to the horses mouth
Old 12-18-2001, 10:25 PM
Better than steak
Arturbo's Avatar
Default Re: block guard for a zc?? (greyzone)
Or contact MarkC because he has a block guard in his ZC turbo.
art
Old 12-18-2001, 10:44 PM
AbaZ's Avatar
As far as I know they dont make one, I bought the Nuformz and STR, both didnt fit for d16 apps.. I ended up sending my block to Endyn and had posting/stud support installed. This is the same type of setup Larry (t.o.o) uses on his 27psi SOHC civic.
Quote "We manufacture aluminum studs that are the exact same alloy and heat treat as the Honda block. We've calculated the point of maximum piston side thrust on both the primary and secondary thrust axis and we drill and tap holes through the side of the block in these locations. We use an extremely high heat epoxy as a sealant and screw the studs (posts in Nascar lingo) in until the contact the outer cylinder wall with a torque of 2 inch pounds. This places one post per cylinder on the exhaust side of the block and two per cylinder on the intake side (primary thrust axis.)
If the torque exceeds the 2 inch pound figure, the posts will deform the cylinder "
So far so good, here is a pic on my ZC
12 studs total
Jeff
Old 12-18-2001, 11:10 PM
greyzone's Avatar
Default Re: block guard for a zc?? (AbaZ)
https://honda-tech.com/zerothread?id=101635&page=1
(scroll down to his thread)
check with this guy, he made his own, maybe he can help you get custom setup
This is his profile name:
nathan's boosted civic
his email is: nathan@boost-up.com
[Modified by greyzone, 12:18 AM 12/19/2001]
89blackef
02-11-2012 04:27 AM
SlAmMeD 91 HaTcH
09-05-2007 07:46 PM
Hcivic88
03-11-2005 02:58 PM
speed_racer012
11-15-2003 08:34 AM
Lamchop0000
07-13-2002 05:11 PM
Quick Reply: block guard for a zc??
