block guard or sleeved block
Old Apr 23, 2006 | 02:44 AM
marksturboek's Avatar
Default block guard or sleeved block
Hi Can someone please help me getting my head around the diffrence in a sleeved block and using a block guard.
1. do you use a block guard aswell as a sleeved block or do you just use it when using stock clyinder sleeves?
2. last of all what would you say are safe WHP figures for running stock a stock sleeved bottom end with a block guard? with forged pistons and rods?
pics of the diffrence would be very much appreciated!
Thanks in advance
cheers,
Mark
Old Apr 23, 2006 | 06:56 AM
Mugencrxsir1's Avatar
Default Re: block guard or sleeved block (marksturboek)
First of all, a sleeved block is totally different than just a block guard. Sleeves that are aftermarket and can hold up 40psi with proper tuning. While stock sleeves, even with a block guard can only hold up to around 25psi with proper tuning, but not for long. A block guard is a piece of metal that suppose to help reduce the chance of sleeve wall. While the aftermarket sleeves are 2 times as thick and are made of iron, which is much stronger than the stock aluminum, iron sleeve.
It depends on you power goals, if you want more than 500+ hp in general, then I would sleeve the block. It you want less than 450hp, than I would stay with the stock sleeves. It's all personal preference, and some will say that you should'nt use a block guard, but it does'nt hurt to have that extra piece of mind. Yes someone will argue this point, but there's no proof that block guards are harmful(Darton has them attached to their aftermarket sleeves.)
Goodluck with making your decision, it should be based on your HP goals.
Old Apr 23, 2006 | 08:18 AM
onefstek's Avatar
the size of the sleaves between oem sleaves and GE sleaves are about four times the size.
Old Apr 23, 2006 | 08:27 AM
EK k kay's Avatar
Default Re: block guard or sleeved block (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">First of all, a sleeved block is totally different than just a block guard. Sleeves that are aftermarket and can hold up 40psi with proper tuning. While stock sleeves, even with a block guard can only hold up to around 25psi with proper tuning, but not for long.</TD></TR></TABLE>
Why do people insist on basing the limits of a motor on psi alone? 30psi on a t25 is different than 30 psi on a t3/t04e 57 trim.
Old Apr 23, 2006 | 08:39 AM
onefstek's Avatar
Default Re: block guard or sleeved block (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">
Why do people insist on basing the limits of a motor on psi alone? 30psi on a t25 is different than 30 psi on a t3/t04e 57 trim.</TD></TR></TABLE>
I will have to dissagree with you. PSI will be the same no matter what turbo you are running. The volume is what will be different, therefore the bigger turbos will allow you to make more hp/tq.
Old Apr 23, 2006 | 10:01 AM
Default Re: block guard or sleeved block (onefstek)
Pounds Per Square Inch(PSI), It's the same no matter what your talking about. Just because you are a smaller person and can swim down 500ft in the ocean, does'nt mean you will not meet the same pressure of the larger person at 500ft. Can you see me drift, pressure is the same. And if you call any company about there aftermarket sleeves, they are rated on PSI.
Old Apr 23, 2006 | 03:02 PM
thanks heaps!
Helps a hell of alot
so when you refer to the power do you refer to it at the wheels or fly?
cheers,
Mark
atm im making 350 fwkw on stock sleeves with a block gaurd @ 15psi on 98oct im now going to sleeve the block
ERL Performance
Performance
10
Dec 16, 2010 05:41 PM
s2kdre
Apr 29, 2005 07:21 PM
SwappedTURBOegg
Nov 29, 2004 12:09 AM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
Twenty36_1
Aug 14, 2003 12:32 AM
