block guard?
Old Oct 16, 2005 | 08:38 PM
the.hamburglar's Avatar
Default block guard?
are they recommended for boosted hondas? i have a b16 that im redoing the bottom end (pistons and rods) so while im at it i might as well?
Old Oct 16, 2005 | 08:41 PM
_gurusan_'s Avatar
Default Re: block guard? (the.hamburglar)
OEM sleeves are just fine unless you are going over say...350 whp.
However there are tons of 600+whp cars doing it on stock sleeves.
Block guards are known to create heat issues as well. I would recommend either sleeving the block or block posting.
Old Oct 16, 2005 | 08:46 PM
Default Re: block guard? (_gurusan_)
block posting?
Old Oct 16, 2005 | 08:49 PM
BlueShadow's Avatar
IIRC block posting is drilling holes through your block so that you can stick a metal rod through it. The end of the post butts up against the outer part of the cylinder. on the outside of the block the post is welded up so it doesn't move.
Old Oct 17, 2005 | 02:14 PM
Default Re: block guard? (BlueShadow)
yeah i dont think ill buy one. i only want to make 300whp
AirbornManJuice
Jan 20, 2015 09:54 AM
1994turbocivic
Jan 17, 2012 09:30 PM
marksturboek
Apr 23, 2006 03:02 PM
sodacan33
May 2, 2004 05:53 PM
