Block Filling...sleeving for under $100?
So I just read this from another forum (link at bottom of post). Basically, they are pouring a material that cures to make a very hard material to re-enforce the your stock sleeves. They drill holes for coolant kind of like a what you see on a block guard.
Anyone try this here?
I searched, and someone talked about this. There was mention of someone making 400+whp with 200+ 1/4mile passes, and still running strong on a B16 after this method of supporting his sleeves.
Input? If it can be done properly, seems like an ok idea. Its less than half the cost of getting your block sleeved.
TIA
where I found it:
http://www.hondaswap.com/forum...63886
TIA
where I found it:
i HAS questions ?
Re: Block Filling...sleeving for under $100? (NoBottleJustThrottle)
Re: Block Filling...sleeving for under $100? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">i believe he still cracked all 4 sleeves</TD></TR></TABLE>
hmm...sounds reliable
Re: Block Filling...sleeving for under $100? (kameleon23)
yea I read your link. Thanks
Basically, the devcon works in that it provides support to the sleeves, BUT it also prevents cooling to actually reach the sleeves, which makes them actually hotter than before...which make them prone to crack.
Thanks again guys...much appreciated
Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">blockguards/devcon is ****** gay.</TD></TR></TABLE>
Do you know from first had experience? Mine works great... block guard that is.
Re: (mike93boost)
Yes, you must be right. I'm quite sure a block gaurd and an aluminum filler have sex orientation.
At least give some backbone to your post.
I will *most likely* be devcon'ing my block for the added support. I don't plan to push 16+ PSI, nor do I really plan on long road racing ventures so I think it's right up my alley. If nothing else at least it gives me some peace of mind.
Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">Do you know from first had experience? Mine works great... block guard that is.</TD></TR></TABLE>
yours works great doing what.
im not going to write out an essay for you guys. do some searching.
Re: (onemanlan)
I didnt read through the whole post that was posted above. Did it say that Devcon would be ok as long as you dont boost too high, and dont road race too much?
I still think that it wouldnt be ideal for me because of how much DD I do. On a week day I only do about 20 miles, but on the weekend I do 300+. I would never go above 13psi though if I did in fact do this.
Re: (mike93boost)
its essentially doing what a block guard does, but instead of a thin piece of metal, its a thicker piece of metal, thus giving more support to the sleeve.
lol... i thought you were being sarcastic so I read the last few pages of the thread..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab »</TD></TR><TR><TD CLASS="quote">i was expecting headgasket, so i ordered a new one took it all apart and bam, cracks like a biotch</TD></TR></TABLE>
That devcon crap is worthless if your not gonna run high power levels theres no point in trying to reinforce it.
and
Block filling is better suited to iron blocks, aluminum block /w cast iron liners are much more sensitive to this.
and
Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">yours works great doing what.
im not going to write out an essay for you guys. do some searching.</TD></TR></TABLE>
Mine works great doing what a block guard is supposed to do. Your the one that knows everything so I wont write an essay out for you. Im glad you have been there and done this already.
with the amount of power people are making these days i dont see it as necessary. unless your looking for make 500+whp then go stock sleeves, no block gaurd, no filing. anything above that sleeve it
Re: (jDMJeRk)
Mine works great doing what a block guard is supposed to do. Your the one that knows everything so I wont write an essay out for you. Im glad you have been there and done this already. </TD></TR></TABLE>
you know how many blocks ive seen that needed to be align bored because they had a block gaurd? they truely dont do anything and pooring that **** in your water jacket isnt the best of ideas either but if you want to do it...Havefun not my motor
i HAS questions ?
Re: (onemanlan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemanlan »</TD></TR><TR><TD CLASS="quote">I will *most likely* be devcon'ing my block for the added support. I don't plan to push 16+ PSI, nor do I really plan on long road racing ventures so I think it's right up my alley. If nothing else at least it gives me some peace of mind.</TD></TR></TABLE>
Read the link. From what was discussed, it hinders cooling significantly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoBottleJustThrottle »</TD></TR><TR><TD CLASS="quote">I didnt read through the whole post that was posted above. Did it say that Devcon would be ok as long as you dont boost too high, and dont road race too much?
I still think that it wouldnt be ideal for me because of how much DD I do. On a week day I only do about 20 miles, but on the weekend I do 300+. I would never go above 13psi though if I did in fact do this.</TD></TR></TABLE>
You'll be more than fine with a stock block at these levels.
right ..all the surface area of the sleves for cooling the cylinders is taken away...so even if the coolant temps dont show overheating...your sleeves will be cooking
OG triple OG
Re: (onemanlan)
added support pushing 16 lbs ???? definatly not needed.
so you guys talkin bout block guard etc, when do you think you need a block guard/any of these sleeve techniques? i want to hear peoples opinions 8psi? 10 psi? 16psi?? 20psi? ?????
Re: (D@nnY)
the DEVCON seems to have backfired on ccfab. sounds like thermal expansion or something cracked the sleeves.
a lot of cars are making high horsepower on stock sleeves.
Re: (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">You'll be more than fine with a stock block at these levels. </TD></TR></TABLE>
You and nerdsports have said the same thing to me. So, much appreciated. I just dont want to worry about it pushing around 12psi on track days, or sometimes on the street.
At that psi, you guys think I should upgrade rods and cylinders? I know the rods are a weak link in the D16z6, but again, at those psi levels would it be that big of an issue as long as I have a good tune?
i HAS questions ?
Re: (NoBottleJustThrottle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoBottleJustThrottle »</TD></TR><TR><TD CLASS="quote">You and nerdsports have said the same thing to me. So, much appreciated. I just dont want to worry about it pushing around 12psi on track days, or sometimes on the street.
At that psi, you guys think I should upgrade rods and cylinders? I know the rods are a weak link in the D16z6, but again, at those psi levels would it be that big of an issue as long as I have a good tune?</TD></TR></TABLE>
Pistons/rods and a good tune will be fine at those levels. Eagle rods will work well (they're inexpensive compared to some other manufacturers) and whatever pistons you feel like running.
