Block decking Milling
Old Mar 26, 2009 | 06:05 PM
boostedteg4dr's Avatar
Default Block decking Milling
My engine builder decked my block today.
It looks like he took a lot off.
Its a b18c1 gsr.
How do I check the clearences?
Whats the clearance supposed to be at?
Old Mar 26, 2009 | 06:32 PM
4g hatch's Avatar
Default Re: Block decking Milling
if he doesnt know how much he took off then i would walk away from him
Old Mar 26, 2009 | 11:35 PM
He knows but i like to know myself...
Old Mar 27, 2009 | 01:51 AM
tepid1's Avatar
You'll have to check your P2V and see if you are good to go....
Old Mar 27, 2009 | 10:45 AM
what should the p2v be?
Old Mar 27, 2009 | 12:17 PM
SD_Lurker's Avatar
HT White Ops
ok well if he knows, then you know too. How much did he say he took off?
Old Mar 27, 2009 | 12:27 PM
.006 he says there is .011 left. but i dont know how much the first machinist took off if any.
Old Mar 27, 2009 | 12:28 PM
JDM1civic's Avatar
if you think he took off that much, maybe you should be worried about piston 2 head clearance.....LOL!
Old Mar 27, 2009 | 07:16 PM
HiProfile's Avatar
I think you're reading that wrong. A stock GSR has a .030" piston to deck clearance, not including the .029" 3-layer MLS gasket.
The easiest way to check is to put in a rod & piston combo of which you know the exact length of. Then clay the head/block at the quench pads. Google will tell you what OEM dimensions are supposed to be. Just remember to add the gasket thickness. It may be a pain, but its faster than finding someone with a mic big enough, or willing to set some rig up to measure it.
revnice
Nov 3, 2015 12:32 PM
tegboy321
Jul 17, 2012 04:17 PM
blackccoupe
Sep 28, 2009 06:14 PM
all-mtr-teg
17
Aug 29, 2007 01:57 PM
KOTSEMOTO
Nov 3, 2002 09:32 PM
