This block anygood?
Old May 27, 2009 | 07:06 PM
precisionsc54's Avatar
Default This block anygood?
Im looking to buy an extra GSR block for my new build. I found this block for a good deal but im not sure if its fixable. My plans were to have it bored .5mm over since I already have some wiseco 81.55 mm low comp pistons. Do u think that .5mm overbored would clean up the cylinder wall? What about the top of the sleeve? Your help is appreciated.
Old May 27, 2009 | 07:42 PM
redlinetuning's Avatar
Default Re: This block anygood?
that's hard to say. bore it, measure it,hone it, measure again. walls to thin?
Old May 27, 2009 | 08:34 PM
eg-owns you's Avatar
if u got it re sleeved id say yes but those chips are pretty big i think the walls would be to thin if u try to bore it out
Old May 27, 2009 | 08:40 PM
SilverEk3dr's Avatar
Might need to bore it then have it decked to see if you can fix everything.
I would prob pass on it though.. Looks like its had a hard life.
Old May 28, 2009 | 04:04 AM
ya I know its really impossible to tell from pics if a .5mm overbore will be enough to clean up the walls. If The seller was closer I might take the chance. But its a 3 hr drive
Old May 28, 2009 | 06:17 AM
if it's cheap enough.. maybe have him meet you halfway. Get it, and maybe sleeve it in the future.
Old May 28, 2009 | 06:22 AM
$200 and i have to drive all the way lol
Old May 28, 2009 | 06:32 AM
Silvertc's Avatar
damn, screw that man. i wouldn't do it. For one the drive, two the cost for just a bare block that needs some decent work? not a good deal man IMO....
Old May 28, 2009 | 06:35 AM
block, crank and mains?
Old May 28, 2009 | 06:56 AM
CerealKiller's Avatar
Only way to repair that would be to resleeve, that chip on the deck is too much.
Old May 28, 2009 | 10:02 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i wouldn't trust that. those are pretty big chips.
Old May 28, 2009 | 11:57 AM
E85B18's Avatar
x2
Old May 28, 2009 | 12:01 PM
dagle's Avatar
yup x3
https://honda-tech.com/attachment.ph...1&d=1243479948
that pic in particular, don't think even decking it would make a good surface for the headgasket to mate (it looks corroded a bit further than surface rust) even if it was decked i think it'd be a gamble for head gasket issues.
edit- err meant if it was milled off it wouldn't be worth it*
precisionsc54
May 28, 2009 04:06 AM
myDC4rox
Jan 17, 2005 10:35 PM
phiberoptik
Oct 29, 2003 11:58 AM
GapxGuy
Dec 26, 2002 05:32 AM
Turbo_Teg
Dec 24, 2002 05:56 PM
