Bleeder valve for turbos
Have any of you guys here used 1 of these or does the hondata do it for us automatically i know they use them in japan i lerned about them from the you tube video mighty car mods.
Installing the components into the ecu is fairly simple if you know how to solder and desolder. Mac solenoid is only two wires and the vacuum lines are simple. This will allow boost by gear and much better control Of the power of the car. Just keep in mind minimum boost is always dictated by the wastegate springs and goes up from there. Some people seem to think with boost by gear you can have no boost in first gear and as much as you need in higher gears.
