the bin i was running when she blew
this is the bin i was running when i broke several ring lands
what can i fix on it?
http://uberdata.pgmfi.org/foru...=3344
EDIT: 12.5 A/F is too lean in boost under any circumstance/setup in my opinion
Fuel Lo looks horrible. Fuel high is OK. Timing seems to be somewhat conservative(depending on fuel being used). Your partial throttle(in Fuel Lo table) may have contributed some extra heat which lead to the outcome. Lot's of variables but, the lack of tuning doesn't help. Good luck w/ the rebuild.
. I've got some pistons for you in my sig.
Phil
i just worked it over. prior toboost i was getting 38 mpg city annd 47 mpg hiway on the bin prior to boost. i then richened it up a lot my car will be running this weekend so ill start tuning it again
SOHC_MShue
Mar 1, 2005 05:42 AM
