billet 62/62 vs BBT72 dyno
#28
Re: billet 62/62 vs BBT72 dyno
Its a modded walbro and its got 1600cc injectors.... Imagine a boost-a-pump and ID2000's I could see someone making 700. Im interested as well if its a BB or not, I know he didnt specify bb for it but he did with the 72 so I am guessing that it is not.
#29
have you guys doubting it ever tired it?...lol
the pump is rewired, modded, 60psi base fuel pressure, 1600's... i dont see why 600hp is so hard to believe.
if i keep the revs under 9500rpm the afr stays in the safe zone... i took it to 10.5k a couple times and the afr would climb to 13:1
the car went 10.0@151 first pass. broke 3rd gear next pass
#30
#32
#34
Damn good numbers. I run a billet 6262 on my DSM and i love it. I make full boost by 4600ish and pull it to 8500 on just a stock *** head with FP2's.
I also run a 5857 billet on my 8.5:1 H22a daily driver. Its just on 15psi tho but its alot of fun. Real good turbos. I try to talk all my friends into billet wheels. None listen tho.
#35
#38
We have a Precision 6265 on my brother's S2000 and we made 835@30 something PSI this turbo is the best street turbo in the market period....
And if you want even more the Precision 6765
#40
Did you guys do anything to compare this directly with a 6262?
I just bought a 6265, but I'm not going to be able to get it on the car for a couple of weeks or so I would guess, and the suspense is killing me!
Thanks for sharing! ! ! !
#41
I would love to see a full boost graf on a 2liter b-series ls stroke with the t4 diveded ballbearing gt35 with the 6262 billet wheel on a divided manifold and twin gates and with pro 1 cams.. I am so tempted I might buy a new setup.. gut damn
#44
I might Be doing just that I'll post up the results when I do. Does anyone have any numbers from a gt35/62mm precision wheel combo?
#46
6262 is a 62mm compressor inducer. Underrated @ 70lbs/min (ive seen over 80)
35r is a 61mm compressor inducer. Rated @ 65lbs/min
Both run T04S housings so they are pretty similar in size by the naked eye. The 6262 billet will flow a lot more tho
