Big oil filters?
Big oil filters?
I dont know if you guys already know this, but an oil filter from a late 80s Mitsubishi Montero with the 2.6L 4 cylinder uses a huge oil filter with the same threads and 0 ring sizes as our cars. It is much larger too. I opened one up and there is nearly double the amount of filter media in it I beat the hell out of my boosted GSR so I like the added insurance of the big filter.
The Mobil 1 part # is M1-105 I don't think it will fit if you use a big Tee thing for your turbo feed but otherwise it fits back there. Happy boosting!
Re: Big oil filters? (Boosted2K)
No drop in pressure that I could see. I do run a shimmed oil pump relief spring as well as an external oil cooler.
FWIW, the new Honda filters are freaking tiny. You could use the S2000 filter which is the same size as the old B series one but Mobil make a superior filter anyways. The Honda ones are mostly made by Filtech anyways, which tend to suck.
Re: Big oil filters? (nfn15037)
Interesting! What store did you actually get it from?
And I guess I missed something a while back with the S2000 filters, I didn't know bigger was better for oil filters.
Re: Big oil filters? (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip »</TD></TR><TR><TD CLASS="quote">so no change on the oil pres. guage? that's cool</TD></TR></TABLE>
No sir, idle and redline is just exactly what it was before.
I got the filter from Autozone Larger isn't necessarily always better, but in the case of a boosted Honda I figure more filtration capacity is better.
I work at a Honda dealership and I can gaurentee that an S2000 oil filter does not fit any other honda, neither does the Insight one just for your info.
Re: Big oil filters? (LVB18Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic »</TD></TR><TR><TD CLASS="quote">I work at a Honda dealership and I can gaurentee that an S2000 oil filter does not fit any other honda</TD></TR></TABLE>
. I better take mine off of my car right away. The cashier at a Honda dealership said so
Phil
Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic »</TD></TR><TR><TD CLASS="quote">I work at a Honda dealership and I can gaurentee that an S2000 oil filter does not fit any other honda, neither does the Insight one just for your info.</TD></TR></TABLE>
Well I don't work at a Honda dealership but I can gaurantee you that that info is incorrect.
Re: Big oil filters? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
Your a dumbass if you think you have a S2000 filter on your car. The threads are different.
Why are you arguing this? You are WRONG. They are both 20x1.5 threads. I have S2000 filters on a B18C1 motor and a D16Z6 motor that I own, not to mention the countless customers motors I use these filters on. Now get the **** out of my thread.
I would just like to confirm that some oil pressure is lost when using a honda oil filter...at least the new filtech ones.
I normally use Mobile 1 filters too, but the local store that carrys em was sold out so I bought an OEM b16a2 filter to use on my b18c1.
I did notice a slight, maybe 5 psi, drop in idle oil pressure.
I think I may try an S2k filter next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">Why are you arguing this? You are WRONG. They are both 20x1.5 threads. I have S2000 filters on a B18C1 motor and a D16Z6 motor that I own, not to mention the countless customers motors I use these filters on. Now get the **** out of my thread.</TD></TR></TABLE>
owned.
sounds good. I'l give the montero filter a try.
owned.
Re: Big oil filters? (CRXDrew)
lol ive allways used s2000 filters on my b series been running strong. one time i took my car to honda and some dumbass did not tighten my drain bolt and all the oil leaked out. it was probally that dumbass who worked at honda!
Thats funny ****.
Yeah as for the S2K filter, that filter was used across the entire model line until two seasons ago when someone figured they could save a couple of pennies by making the smaller ones and selling them for the same price. The only filter that will not work and is vehicle specific is the insight filter which has already been previously mentioned.
Re: Big oil filters? (2000civicsi)
I still have a **** load of those old big filter that they use to have. I ordered like 60 filters. I think I can still get those big ones from my dealer.
I've been told by a person or two that the newer smaller filters have the same size filter elements as the bigger ones. The "empty" volume was just decreased. Im going to cut apart one and check this out myself after my next oil change.
i ran the oem small filter for a bit then went to fram (cuz dealersip was closed) and i noticed that with the oem filter me readings were
cold idle - 75psi
warm idle - 25psi
cruise above 3000rpm - 60psi
where as my larger fram filter readings were
cold idle - 60psi
warm idle - 25psi
cruise above 3000rpm - 50psi
does the small difference in psi actually make a difference ??
the only thing i can think of is if it blows thru the turbo seals
cold idle - 75psi
warm idle - 25psi
cold idle - 60psi
warm idle - 25psi
dclub01
05-01-2003 03:22 PM
