big cams plus maybe nitrous
Old Apr 8, 2007 | 03:45 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
Default big cams plus maybe nitrous
so i got a fully built ls/vtec for n/a it is 13:1 cr the head is omni valvetrain and blox b cams i was wondering if it was possible to put nitrous on this motor. i heard that my cams might be too big! for nitrous i want to put like a 80 o 100 shot just to get past the 300whp in my car! thanks for the help! also by the way i am tuned on hondata s200
Old Apr 8, 2007 | 04:05 PM
raceACCORDingly's Avatar
nitrous and high compression go hand in hand. get it tuned. if your cams are high duration and high lift you will probably want to advance the exhaust cam via cam gear. Nitrous will respond better if the increased exhaust duration is gained by opening the exhaust valves earlier in the cycle.
Old Apr 17, 2007 | 08:26 AM
Suck my DX's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">nitrous and high compression go hand in hand. get it tuned. if your cams are high duration and high lift you will probably want to advance the exhaust cam via cam gear. Nitrous will respond better if the increased exhaust duration is gained by opening the exhaust valves earlier in the cycle. </TD></TR></TABLE>
exactly...
and with that said you need to realize that your engine will need two different tunes to make optimum power in N/A and nitrous...
if you need me to elaborate let me know
BolivianDc2
Aug 24, 2003 08:10 AM
hatch101
Aug 9, 2003 04:33 AM
QuestRacingType-R
Feb 12, 2003 07:47 PM
cjames235
Sep 20, 2002 07:47 AM
AllMotorITR
Dec 13, 2001 07:43 PM
