Is this to big
Old Aug 10, 2003 | 01:49 PM
deeweezy's Avatar
Default Is this to big
WOULD THIS BE TO BIG FOR A 94 GSR http://store.yahoo.com/cheaptu....html
Old Aug 10, 2003 | 01:53 PM
94gsr4dr's Avatar
Default Re: Is this to big (deeweezy)
No, it won't have the best spool characteristics, but it should have strong top end power. There are lots of people on this board that run turbos considerably bigger then this one with no problem. That is actually the size i am most likely going with on my 94.
Old Aug 10, 2003 | 09:47 PM
RicerRacing69's Avatar
Default Re: Is this to big (94gsr4dr)
Im running that exact turbo right now on my ls motor and its doesnt fully spool till about 4grand rpm's but thats when all hell breaks loose
Old Aug 10, 2003 | 09:48 PM
rjardy's Avatar
Not to big at all
Rob
Old Aug 10, 2003 | 10:54 PM
deeweezy's Avatar
thanks
Old Aug 11, 2003 | 02:15 AM
pissedoffsol's Avatar
25 Year Member
Default Re: (deeweezy)
tiny
Old Aug 11, 2003 | 05:51 AM
Turbocivic94's Avatar
you think that's big. check this turbo for my lsvtec
can someone make thes pics bigger. Thanx
Modified by 25 PSI CRX at 6:17 PM 8/11/2003
Old Aug 11, 2003 | 11:13 AM
Default Re: Is this to big (rota92)
In Hartford
Old Aug 11, 2003 | 12:07 PM
mike1114's Avatar
deeweezy,
I got the exact same turbo your looking at for my GSR. I plotted our motor on a compressor map for this turbo and it is perfect!!
If your looking for good all around street driver turbo this should be great!!
Old Aug 11, 2003 | 01:03 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Is this to big (mike1114)
my brother ran one of those on his turbo ls, full spool around 4500 and that was with missing exhaust manifold nuts = exhaust leak.
Old Aug 11, 2003 | 01:22 PM
tegasaurus's Avatar
Default Re: Is this to big (PreIudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreIudeSI &raquo;</TD></TR><TR><TD CLASS="quote">my brother ran one of those on his turbo ls, full spool around 4500 and that was with missing exhaust manifold nuts = exhaust leak. </TD></TR></TABLE>
2 psi @ ~3300
6 psi @ ~3800
10 psi @ ~4100
very nice turbo, you wont be dissapointed.
Old Aug 12, 2003 | 02:03 AM
deeweezy's Avatar
what size downpipe do you think i should get with that turbo i was thinkin 3in downpipe from maxrev
Old Aug 12, 2003 | 05:58 PM
ChadB's Avatar
I am running the that same turbo size.. It spools about 2500... I ran a 13.9 with 6 psi...At 106 MPH.. I 've be ruuning any were to 10 - 12 psi and it's crazy.... So I should be low 13's or high 12's...
Old Aug 12, 2003 | 06:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (ChadB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChadB &raquo;</TD></TR><TR><TD CLASS="quote">I am running the that same turbo size.. It spools about 2500... I ran a 13.9 with 6 psi...At 106 MPH.. I 've be ruuning any were to 10 - 12 psi and it's crazy.... So I should be low 13's or high 12's...</TD></TR></TABLE>
Im sorry but that does not sound correct to me. 2500 spool?
Old Aug 12, 2003 | 06:40 PM
Disco Stu's Avatar
Default Re: (HybridcivicLS-T)
I think he just means that it starts to spool at 2500. That sounds about right (maybe a little bit too low though) if you go by what tegasaurus said that he gets 2 psi at 3300.
Down4ce
Jul 11, 2007 01:50 AM
NightHawkC5
Jan 16, 2003 08:56 AM
J2turbo21
Jan 6, 2003 12:00 PM
N2X0
Oct 21, 2002 05:24 PM
DRAGLS
Feb 25, 2002 04:58 PM
