best valve train for turbo?
im running a poor man's type-r. drag turbo kit. eagle rods. wiseco pistons. block guard. just trying to find te best valve train for boost...mainly the valves. thanks in advance
Re: best valve train for turbo? (laocivic)
i don't know much about supertech but from what i hear its good stuff. i have ferrea and they're a reputable name in valves. you can't go wrong with either one.
Re: best valve train for turbo? (Mikey3000)
thanks a lot. i guess ill go looking for ferrea or supertech. which is best price? im looking at a full valve train.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic »</TD></TR><TR><TD CLASS="quote">thanks a lot. i guess ill go looking for ferrea or supertech. which is best price? im looking at a full valve train.</TD></TR></TABLE>
my ferrea setup with valves, springs, retainers, locks, guides, keepers etc was over 1k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic »</TD></TR><TR><TD CLASS="quote">well mayb ill just shoot for valves, retainers, and springs...think i would b ok with that?</TD></TR></TABLE>
You'd honestly be fine on stock valvetrain
But yes, this is all you would need for a high-reving motor.
i ♥ snails
i dont get it, why would you want to replace the valves? your just running a drag turbo kit, not bashing the kit, but i think money could be spent where else where, springs and reatainers are a good investment, new valves? no so much with your setup.
Re: (quicksilver1689)
im just trying to research and find the best setup. this is my first turbo setup on my own car. would it b ok for me to rev up to 9K on this setup?
Re: (laocivic)
I wouldn't recommend stock valvetrain on a turbo, no matter how small the turbo is. Stock springs only have about 25# with the valve closed. Factor in some boost...can you say float?
We have had great results with REV valves and their valvetrain.
We have used the valve in big turbo big HP motors as well and it holds up great.
I can get you a price on it.
I would recomend at least Valve Job that PR3 head.
i use supertech black coated valves and they have held up great. the price is good too. i burned up a srp piston with nitrous and the valve was fine except for the melted aluminum on it.
Re: best valve train for turbo? (dbiker207)
well i've known many ppl who've run 300 hp and a stock motor. it ran fine with a good tune... i just want a strong head.
i ♥ snails
why should he replace the valves? that is retarded.
Get retainers and springs so you dont have valve float, which you most likely wont unless your spinning it pretty high. RPM is the main factor in valve float. New valves are such a waste of money in your situation, stock vtec heads have been taking to over 500+whp easily without problems.
Mr. Badwrench
Re: best valve train for turbo? (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">
my ferrea setup with valves, springs, retainers, locks, guides, keepers etc was over 1k</TD></TR></TABLE>
mine was a little under, but thats through my shop.
it isnt the turbo that necessitates the valvetrain, it is how high you are going to spin the engine.
Becouse the stock ones tend to break.
a supertech valvetrain cost you a bit over $500 and are well spent.
http://www.laskeyracing.com or just talk to mike laskey(ninesecrx) at the forum.
Valvedrop=total destroyed engine
