Best Turbo Setup For GSR?
Old Apr 13, 2002 | 09:43 AM
phear's Avatar
Default Best Turbo Setup For GSR?
What is the best turbo setup for GSR.
I have a 93 DX Coupe Civic With a b18c1, Type R Cams, Cam Gears, BBK 255LPH High Performance Fuel Pump, Clutch Master Stage 3, JDM Type R LSD Tranny, MSD Ignition, No Power Steering, 17 wheels, DelSol Dual-Core Radiator, LightSpeed Hyper Flo Intake, LightSpeed Stainless Steel Cat-Back Exhaust System
If i need to change anything above for turbo, i will do it
Thanks
Old Apr 13, 2002 | 11:24 AM
phear's Avatar
Default Re: Best Turbo Setup For GSR? (phear)
k
Old Apr 13, 2002 | 03:52 PM
int3gra's Avatar
hahahahahahaha
"Sell weed and have your engine built to run 15 lbs of boost...then wax the V8's"
Old Apr 13, 2002 | 04:01 PM
phear's Avatar
Default Re: Best Turbo Setup For GSR? (int3gra)
Need To Know what i need to build that
Old Apr 13, 2002 | 07:06 PM
KooK's Avatar
Mustang Sally
If I were you... I would rebuild the engine if its over 70-80k (thats just me), But if you dont wanna go with a custom kit, Drag III is your best choice. Also, if you want higher PSI than look into trying to harden your internals with Endyn, Crowler or whatever parts fit your needs.
http://www.importparts.com is a great place to buy turbos and other stuff.
Old Apr 13, 2002 | 11:51 PM
phear's Avatar
Default Re: Best Turbo Setup For GSR? (Tapeworm)
rebuilt engine like what everything?? i has 90k on it
Old Apr 14, 2002 | 06:43 AM
Yellow Dragon's Avatar
Okay...I'm guilty. It was my tribute to the guy that always puts, "smoke weed everyday" in polls. I figure sell it, then you'll have the $$ you need to build your engine. J/K
Well, if you wanted to build your engine, I would put new rods, pistons, rings, bearings. Then send your shortblock to Benson and get it resleeved. Get a blockguard as well. Run lower compression...then run that bitch up to 15+ psi.
Old Apr 14, 2002 | 07:11 AM
phear's Avatar
Default Re: Best Turbo Setup For GSR? (Todd C)
HAHA Weed owns
aight how much can it cost replacing these things and what brand is good to buy?
Old Apr 14, 2002 | 07:14 AM
phear's Avatar
And Right now im runnin a 80 Wet Nos shot. Sould i sell the kit and buy stuff to rebuild it? or keep nos and rebuilt and go with turbo.
W00T Smoke weed btw :D@!~~
Old Apr 14, 2002 | 07:59 AM
Sell the nitro...once you build the engine, you will be set. No need for nitro at that point. (15+ psi). I would contact Benson or Golden Eagle. Call them up and they'll let you know what you need to do.
Don't forget to upgrade your clutch, flywheel, and get a LSD if you can.
Old Apr 14, 2002 | 08:01 AM
phear's Avatar
I Have Clutch Master Stage 3
i have stock flywheel
and i have a jdm type r lsd tranny
Old Apr 14, 2002 | 08:55 AM
Cool, you should be fine with that setup. I'll see if I can't get a link for you to contact someone about getting your engine built.
Old Apr 14, 2002 | 09:09 AM
phear's Avatar
sould i buy a skunk2 intake manifold! since i only have the stock gsr one right now
Old Apr 14, 2002 | 12:54 PM
2K_TEG's Avatar
If you are going turbo now, you should buy a turbo...then upgrade the stuff that really doesn't *need* upgrading later. Get yourself some forged internals, some sleeves if you can and a turbo kit, whether it be custom or what have you. Then worry abou things like IMs and fuel rails. This is all based on you not having $10K to spend all at once.
Old Apr 14, 2002 | 06:48 PM
SPOON_BeIgHtEeNsEe's Avatar
u dont need that JDM ITR tranny so just sell it to me...
Old Apr 14, 2002 | 07:02 PM
phear's Avatar
Default Re: Best Turbo Setup For GSR? (SPOON_BeIgHtEeNsEe)
hehe
no mine
DC2GSR808
May 7, 2014 11:14 PM
eglsbuilt
Oct 23, 2008 04:21 PM
MooFX
Oct 2, 2004 04:56 AM
jbell
Feb 5, 2004 04:16 PM
scarface
Nov 15, 2002 11:12 AM
