Best gauges for nitrous?
Old Sep 3, 2003 | 09:20 PM
vtecman253's Avatar
Default Best gauges for nitrous?
well tomorrow i'm putting the nitrous kit on, but first i'm swinging by the store to pick up a b&m fpr and some gauges. I'm buying the bezel that has inserts for two gauges. One I have already decided should be a/f ratio. What should the other be? Fuel pressure, oil temp, exhaust temp, etc?
Old Sep 3, 2003 | 09:54 PM
laughinxxx's Avatar
New User
Default Re: Best gauges for nitrous? (vtecman253)
Fuel pressure, nitrous pressure, and a WBO2 if you can afford it. You can get a bottle mounted gauge for the nitrous. They are cheap, accurate, and your pressure won't be changing drastically unless you light a fire under the bottle. It would probably be beneficial to get a fuel press. gauge that you can see while driving, but I'm just running an underhood gauge that I check before I run.
Old Sep 3, 2003 | 09:59 PM
tegasaurus's Avatar
Default Re: Best gauges for nitrous? (laughinxxx)
you don't need any of those... get a bottle heater, pressure gauge (bottle mounted) and a wideband o2. You'll love me after you get the bottle heater... its night and day difference.
bossm
Dec 22, 2008 08:16 AM
tweekerz
Aug 22, 2005 02:02 PM
JamesQ
Oct 18, 2004 11:26 PM
megotvtec
Apr 28, 2004 12:31 PM
3 plus 1
Mar 20, 2004 11:08 PM
