Best EGT placement ????
Old Jun 29, 2004 | 04:27 PM
CRVRX's Avatar
Default Best EGT placement ????
Can the EGT sensor be place in the down pipe for more of an Average reading ?
Thanks,
underpressure02's Avatar
Default Re: Best EGT placement ???? (CRVRX)
#3 cylinder.
Old Jun 29, 2004 | 04:33 PM
ScrapinSi's Avatar
Default Re: Best EGT placement ???? (underpressure02)
Now the important question... WHICH is #3? Is it #3 from the distributor or #3 from the crank?
Also, what should the EGT readings be? My buddy on his shadow tunes his car to 1600-1650 deg Farenheit, but his motor isnt aluminum.
Old Jun 29, 2004 | 06:01 PM
BROOD's Avatar
Default Re: Best EGT placement ???? (ScrapinSi)
#1 cylinder starts near the primary engine drive (timing belt), #3 cylinder is two cylinders away from the distributor. Try to keep it within 1" of the manifold falnge if possible.
Installing the EGT probe in the DP will work but this gives an average temp of all cylinders and after a slight amount of cool down. If one cylinder is having a/f issues it may be masked by the other well running cylinders and you may not know you have a problem until too late. You can not accuratly compare those readings with readings taken from the #3 runner.....they will not match up.
EGT's are best used as tooling tools to use in conjunction with a good wideband sensor.
Old Jun 29, 2004 | 06:26 PM
Did you search? This question is asked like 5 times a week.
Old Jun 29, 2004 | 06:44 PM
Muckman's Avatar
Moderator in Chief
Seriously. And I respond to these everytime the same way. #3 cyclinder BEFORE the turbo. Within 3" of the exhaust port.
russ-89
Dec 19, 2017 12:07 PM
EFwithS2000taillights
Jul 9, 2006 02:01 PM
Boostage
Aug 31, 2004 04:33 PM
playAho
Aug 16, 2004 12:11 AM
hate me.
Aug 11, 2004 07:17 PM
