Best clutch for D15z6 turbo (6 psi)
What is the best Clutch for my D15z6 turbo?
I think the max power is 180 pk.
It's a daily drive and always drive on the streets.
I like the ACT strage 2 kit or is a 6 Puck kit better for turbo?
The pressurebearing and topbearing (sorry i'm from The Netherlands) Is it a must to take this OEM? Or the bearings are good from ACT? I heard bad story's about ACT bearings is this true?
Sander.
Sander.
Re: Best clutch for D15z6 turbo (6 psi)
A stage 2 will be fine for that amount of power. A 6 puck (especially if unsprung) is going to have a harsher engagement and is not necessary for that power level. I'm not sure about the bearing issues. I have always used whatever came in the kits and been fine. I have had good luck with Exedy clutches but for that little power any of the major brands should be fine.
Spec clutch and get a 6 puck and be down with it. then theirs no need to worry about anything slipping if you want more power and last longer than organic disc
I read positive things about Competition Clutch kits.
Are these better than ACT?
What kind of stage I need for my 6 psi d15z6 turbo?
