Benson Sleeve Question
Old Sep 28, 2003 | 11:22 AM
95c1v1cs1's Avatar
Default Benson Sleeve Question
Why do some of their sleeves look like this...
and others look like this...
I'm just curious about the gold ring in the first one and not in the second one... Is one an older version or something???
Thanks
Corey
Old Sep 28, 2003 | 12:11 PM
Boostfed's Avatar
New User
Default Re: Benson Sleeve Question (95c1v1cs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 &raquo;</TD></TR><TR><TD CLASS="quote">Why do some of their sleeves look like this...
Thanks
Corey</TD></TR></TABLE>
Very simple the first pic is with a copper O ring installed and the second is without one. It would be a customer request to have the O ring or step deck, step deck has the sleeves slightly higher than the deck for sealing purposes, usually between .001" ti .004" above the deck
Old Sep 28, 2003 | 01:27 PM
-iLLuZioN-B18C1's Avatar
Default Re: Benson Sleeve Question (Boostfed)
is there a benefit to copper or not?
Old Sep 28, 2003 | 01:39 PM
integranator's Avatar
Default Re: Benson Sleeve Question (-iLLuZioN-B18C1)
y do the sleeves in the second picture look thicker than the ones in the first?
Old Sep 28, 2003 | 02:00 PM
95c1v1cs1's Avatar
Default Re: Benson Sleeve Question (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">y do the sleeves in the second picture look thicker than the ones in the first?</TD></TR></TABLE>
Bore.
Old Sep 28, 2003 | 02:25 PM
spoolinlude's Avatar
I live under a rock
They're not, look close, the O-ring is simply sitting on top of the cylinder, you can see that they are the same if you look just under the copper part
Old Sep 28, 2003 | 03:31 PM
95c1v1cs1's Avatar
Default Re: Benson Sleeve Question (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">They're not, look close, the O-ring is simply sitting on top of the cylinder, you can see that they are the same if you look just under the copper part</TD></TR></TABLE>
The O-ringed one is 84mm and the other is Stock or 81mm...
Old Sep 28, 2003 | 06:21 PM
I live under a rock
so I can't eyeball 3mm......... o well slight on me
Old Sep 29, 2003 | 04:14 AM
g2turbo's Avatar
hey thats my block
the bottom one is mine its 81mm and i opted for the stepped deck instead of the o-ring option
Old Sep 29, 2003 | 07:16 AM
earl's Avatar
Default Re: Benson Sleeve Question (g2turbo)
You can choose a stepped deck or O-ring with Benson at no extra charge. Either option works great. Benson likes the O-ring best but I lean toward the step deck. Personally I use both styles with equal success.
Old Sep 29, 2003 | 09:34 AM
TurboAce's Avatar
hey the top one is my block
Old Sep 29, 2003 | 12:11 PM
accordfreak's Avatar
Default Re: Benson Sleeve Question (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">You can choose a stepped deck or O-ring with Benson at no extra charge. Either option works great. Benson likes the O-ring best but I lean toward the step deck. Personally I use both styles with equal success.</TD></TR></TABLE>
with the o-ring option, what kind of gasket do you use?
Old Sep 29, 2003 | 12:15 PM
Boostfed's Avatar
New User
Default Re: Benson Sleeve Question (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">
with the o-ring option, what kind of gasket do you use?</TD></TR></TABLE>
Stock headgasket if stock bore or .5mm over, if B20 or CRVTEC then stock B20 headgasket, you can also use a Cometic MLS gasket but not the HP gasket with the extra fire ring. Also if you are overbore you can get stock overbored gaskets from GE and RS Machine.
Old Sep 29, 2003 | 03:31 PM
Flamenco-T's Avatar
Just remember, O-ring block goes with Non Oringed gasket, and vice versa.
2 copper O-rings won't go together.
With Benson, You can't go wrong, I have had O-ringed and step decked block with great success. Either way will work fine
stan
Old Sep 30, 2003 | 08:20 AM
95c1v1cs1's Avatar
Default Re: Benson Sleeve Question (Flamenco-T)
Thanks for the great info.
Benson
Corey
Old Sep 30, 2003 | 10:35 AM
Muckman's Avatar
Moderator in Chief
This thread should be added to a FAQ.
jacoop86
Dec 18, 2007 08:11 AM
vega_ROCKS
Oct 25, 2006 03:42 AM
RCautoworks
Welding / Fabrication
12
May 20, 2006 02:23 PM
SnOOpY-NO
Jul 20, 2005 11:56 PM
JMD
Apr 3, 2004 06:03 PM
