before turbo what?
Old Dec 30, 2001 | 01:08 PM
95gsr's Avatar
Default before turbo what?
what should I get before my turbo thanks Luis
Sorry not much time to type
Old Dec 30, 2001 | 02:38 PM
paulzy's Avatar
Default Re: before turbo what? (95gsr)
I suggest getting a good working search button before anything else...it's worth the price
Old Dec 30, 2001 | 08:36 PM
95gsr's Avatar
Default Re: before turbo what? (Slow_ass_4dr)
i tried searching i can not find anything.
Old Dec 30, 2001 | 08:40 PM
ForcedAccord's Avatar
Texas B*tch!
Well I mean it just depends on how much boost you want to run. If you want to run average boost on a stock internal engine, then really just be sure to have the right fuel setup so that you can support the boost pressure.
You might also want to do a compression test on your engine, see if there is anything that needs to be reworked.
Just make sure you are smart about how much boost pressure you run. If you want to run higher than average boost, then you might want to consider lower compression pistons <-- Correct me if I'm wrong please, high compression engines + boost = ouch.
Feel free to add on.
Old Dec 30, 2001 | 08:46 PM
95gsr's Avatar
Default Re: before turbo what? (ForcedAccord)
I will be doing comp test on thursday. Anything else I should check up on.
Old Dec 30, 2001 | 08:47 PM
Texas B*tch!
You should check up on my little turbo kit that I'm selling... haha.
No other than that, you will need new plugs probably, just make sure the engine is running good before you slap a turbo kit on there.
poormans_typer69
Jul 22, 2008 03:07 PM
92civtegra
Aug 15, 2007 08:26 PM
Dasani
Jul 7, 2006 05:13 AM
AccordCD5
Oct 14, 2005 01:10 PM
DualKnuttz
Mar 14, 2003 06:52 AM
