bead roller?
Old Feb 20, 2006 | 01:41 PM
Superorb's Avatar
Default bead roller?
where can i find a cheap bead roller to do the beads on my intercooler piping? Or, is the easiest way to just have it welded on there?
Old Feb 20, 2006 | 01:46 PM
non-VTEC's Avatar
Default Re: bead roller? (Superorb)
just run a weld across the ends of the pipes.......
Turbo-charged's Avatar
my bead roller was expensive and its a peice of crap...what material are you pipes?
Old Feb 20, 2006 | 01:51 PM
Superorb's Avatar
I should be using aluminum. I did some aluminized steel already with a flux core mig and it came out like crap, heavy and bulky. I'm going to get some mandrel bends, test fit it all and have them welded by a shop.
Old Feb 20, 2006 | 01:53 PM
project dc2's Avatar
Default Re: (Superorb)
my bead rolelr cost 600$ .. so yea .. its expensive
Old Feb 20, 2006 | 02:01 PM
Default Re: (project dc2)
i always bead roll aluminum....if you buy aluminum from vibrant it comes bead rolled already.
Superorb's Avatar
got pm phil
Old Feb 20, 2006 | 02:07 PM
Superorb's Avatar
who's vibrant?
Old Feb 20, 2006 | 02:11 PM
2point2's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i always bead roll aluminum....if you buy aluminum from vibrant it comes bead rolled already. </TD></TR></TABLE>
not always. my 2.25 stuff was, my 2.5 stuff wasn't.
Default Re: (2point2)
all the new stuff is..the old stuff wasnt. i go through a TON of vibrant stuff haha
Old Feb 20, 2006 | 02:18 PM
Superorb's Avatar
where can I get some aluminum mandrel bent intercooler piping that won't cost me an arm and a leg? I figure 2.5" cold and 2.25" hot side piping for my f22 motor.
Old Feb 20, 2006 | 02:59 PM
kamAccord's Avatar
You didn't bead roll mine. Even the manifold turned out F...d up that you guys made that I informed you about almost a year ago and called you five weeks in a row and you still refuse to correct the problem.
Old Feb 20, 2006 | 04:13 PM
Weq's Avatar
Weq
sorry gotta gloat.
mandrel bent thin walled alluminium, bead rolled.
Old Feb 20, 2006 | 04:16 PM
Superorb's Avatar
lr mr. gloater... where'd you get that and what's it for? you guys and your civics/tegs can find premade piping. it's the accord guys that suffer
Old Feb 20, 2006 | 06:11 PM
JdmEKCivic's Avatar
If you want a quick fix I just put a ring of JB weld on the end of the pipes .
Old Feb 20, 2006 | 06:16 PM
Superorb's Avatar
i don't want a quick fix.. i want it done right the 1st time.
Old Feb 20, 2006 | 06:27 PM
Weq's Avatar
Weq
its not pre-made. its all custom work/bent done by guys here in australia. im 90% sure they supply fullrace with there alluminium products also. Those beads were done on a pretty expensive roller though. Like the others have mentioned, they arnt cheap to buy for a once off thing.
Old Feb 20, 2006 | 06:34 PM
Superorb's Avatar
ok, so am i looking at getting a bunch of 90 bends or u bends and cutting them myself? that's not a problem, i dont mind doing labor. i swapped my other car from an auto to a 5sp. what would be the best way to cut angles in the aluminum piping? a hacksaw just isn't any good for that, i need a nice clean cut so it's not difficult to line up.
Old Feb 20, 2006 | 06:37 PM
NJIN BUILDR's Avatar
I made a bead "roller" out of a set of vicegrips.I ground back the top jaw leaving a rib, and ground a slot in the bottom jaw.Took a little tweeking but it works very good now.I just crimp the bead around the end of the tubing.
Glenn
Old Feb 20, 2006 | 06:40 PM
Superorb's Avatar
got pm
Old Feb 20, 2006 | 07:29 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superorb &raquo;</TD></TR><TR><TD CLASS="quote">i don't want a quick fix.. i want it done right the 1st time.</TD></TR></TABLE>
*tear*
Old Feb 21, 2006 | 06:52 AM
drumking15's Avatar
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I made a bead "roller" out of a set of vicegrips.I ground back the top jaw leaving a rib, and ground a slot in the bottom jaw.Took a little tweeking but it works very good now.I just crimp the bead around the end of the tubing.
Glenn</TD></TR></TABLE>
exactly what i did...works great...just takes some time
Old Feb 21, 2006 | 07:18 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
There'd be a lot more fast Hondas on the road if everyone thought like you.
Old Feb 21, 2006 | 12:48 PM
Superorb's Avatar
can you guys post pics of the home made ones yall made?
Old Feb 21, 2006 | 12:59 PM
640K Crew's Avatar
wonder if this would work?
http://cgi.ebay.com/ebaymotors...QrdZ1
