BC crower stg. 2 NA cams?
ok I wanted to pick up a used greddy kit here locally and boost 6-8psi, my current motor is stock gsr with flat valves, ti ret., dual valve springs and bc stg. 2 NA cams, my question is what kind of problems will i run into with this set-up? too much overlap with cams? Im in the process of building a turbo motor but i cant wait i just want to feel boost now!!
Re: BC crower stg. 2 NA cams?
NA cams work great on the LS. We use 404s in our LS at the shop and made 379 on a stock bottom end.
although I will warn you BC cams are starting to be more like BS cams! we refuse to even carry them or order them at our shop. the last set of valvesprings we tested had 3 more lbs of seat pressure than oem
what aftermarket cams are good for the 3076? But why do I see or hear people running sk2 pro2 stg 1 cams, those cams are way more agressive then the stage 2 I got.
Japankid
07-24-2009 07:12 PM
LaOstha
08-03-2006 09:16 PM
thehatchninja
06-10-2005 11:37 AM
