bb2v ticking sound
Old Aug 20, 2014 | 12:03 PM
Project_SOHC_EX's Avatar
Default bb2v ticking sound
Finally put the motor together
Setup
B20v stock block (high compression) motor from jdmengine depot
Fully built gsr head supertec valve train .5 mm over on the valves itr cams fresh valve job....girlfriend destroyed my remote start after the build the car had this habit of turning itself on without me manually hitting the button to do so...I pinched the brand new seal.on the itr oil.pump
during reassembly had an extra changed lil hit not the gray stuff it was all.good ...The car automatic start while we had the timing belt off...thought we bent a valve...so we readjusted b uh spec for a gsr cylinder head .006-.007 on the intake side .007-.007 on the exhaust according to all data...still here the noise jot as loud b UT still there none the less...called machine shop and was told to look into the lma's
Project_SOHC_EX
Aug 26, 2014 06:15 PM
big-cat
Jan 6, 2010 05:59 AM
jdmlude_dude
Apr 30, 2006 06:54 AM
jdmlude_dude
Mar 17, 2006 03:44 AM
Drizzo
10
Dec 19, 2005 07:41 PM
