Banging on 3 cylinders?...Need sum input please!
Ok ever since this crappy cold freezing winter storm...my cars been running a lil rough on startup, warm up...havent had a chance to clean out the iacv due to weather, which i thought was the trouble and there is no fitv...
so today i was driving...and once in a while it would seem to misfire or cut out for a sec or jerk...and later on it started to do it more often...finally its pernament, and it feels like its running on 3 cylinders...my afr is running a lil leaner then it was on 4 cylinders...
Im running on stock injectors for now with fjo injector driver, running no boost yet, got it set to run on n/a for now...and hondata s300...it was running perfectly fine until this cold weather...
To me, it seems like an injector isnt opening up since its running leaner, the injectors are low impedence, tomarrow im going to double check my timing, spark plugs, plug wires, and injectors and ecu...but hopefully its just a messed up injector...i pulled them from an accord...
But i just want sum input to help identify this culprit, it happened later today this evening...I hate this cold weather! my car doesnt like it! haha..
Thanks guys!
Thanks guys!
yusoslo
Sep 25, 2004 07:41 PM
CimorelliCRX
23
Oct 2, 2003 10:28 AM
