Ballistic1350's LSVTEC BB STC Reaper results
A couple weeks back the car was wrapped up and put on the dyno at 4130 Fabrication and was tuned by Randy @RSTech-racing, I'm really impressed with what the car did on 93 pump. It should be nasty once I get everything straightened out with the block... long story short the block is cracked at the bung for the oil pressure sensor. It gushes oil enough to where I shouldn't drive the car and need to get it repaired asap. So I spent the last week pulling the block and taking it back to the machinist who built it, since he should have caught the crack in the first place. So I haven't even been able to drive the car. I still can't get over how well this turbo did on pump alone, really glad I'm ditching my STI.
Quick rundown on parts:
B18a RS machine open deck block
84 mm manley pistons
turbo tuff rods
ARP mainstuds
ACL bearings
ARP headstuds
ATI damper
Ported GSR Head
Toda Springs
Ferrara Valves
Bronze guides
ITR cams
AEM cam gears
Skunk2 ultra street intake manifold
Skunk2 74mm throttlebody
Hondata COP with s2000 coils
Ball Bearing STC Reaper from TheShodan with high temp coating on exhaust housing
Go-autoworks Ramorn with high temp coating and downpipe
Tial 44mm wastegate
Full 3" exhaust
DEI titanium wrap and turbo blanket
ID1000 injectors
Walbro in tank pump
Aeromotive FPR
Skunk2 composite rail
Tuned on Hondata s300v2 made 563whp and 439ft-lbs on 18 psi 93 pump gas
Thanks again to TheShodan for my many pm's about what turbo to run and of course the turbo, Wayne @4130, and Randy for the tune
turbo tuff rods
ARP mainstuds
ACL bearings
ARP headstuds
ATI damper
Ported GSR Head
Toda Springs
Ferrara Valves
Bronze guides
ITR cams
AEM cam gears
Tial 44mm wastegate
Full 3" exhaust
ID1000 injectors
Walbro in tank pump
Aeromotive FPR
Re: Ballistic1350's LSVTEC BB STC Reaper results
Probably because of the itr cams. I was going to run skunk2 pro 1 cams with my ported head, but the max lift on my toda springs don't allow me to run them. Maybe in the future I'll upgrade but till them I just want the car running with no issues
If anyone has any ideas otherwise I'm all ears though, this is my first Honda after all
I'll agree with you there, I actually dropped the motor off over the weekend, so they should be tearing it apart now. I'd hate to scrap a sleeved block over something as stupid as a little crack on the outside of it
I was forced to use a donut for the oil line to VTEC but it all helded up and worked out fine afterwards, relocated the oil pressure sensor to the donut too .....had that motor for 2.5 yrs....
Yeah we tried the whole tap it then plug it route... still leaked everywhere. Little update from the shop, def going to weld it shut and just run without the sensor
the Toda's have a max lift of 12.5mm. The GSC T1s would be great however thats cash I don't have at this point. I agree seems weird that it falls off so much up high
My buddy cracked his block just taking that damn sensor off lol. Ended up patching it with some aircraft jb weld type stuff and it worked surprisingly.
I have seen ITR cams carry power to nearly 9K many times. Something doesn't seem right. The more boost you ran, the sooner it peaked, and fell off a cliff each time.
