Bad Map sensor ?
Got a GM 3 bar map sensor which i bought new used for 500km so far.
car runs smoothly for 15 mins and then shuts down while driving, try to restart the car and no luck, i hook up the laptop (hondata s300) and no reading from the map sensor.
i hook up the stock map sensor and the car runs again perfectly, cant drive the car on GM map sensor any more.
I did open GM map sensor cleaned it and checked its wiring all over again and everything is fine.
if i leave the car to cool down the GM map sensor works. took the car to the dyno and did 2 runs and after that this happened to me.
did my map sensor go bad? im on the edge of ordering a new one.. i said ill double check with HT before wasting a good 100$.
Thanks.
Thanks.
