Bad compression numbers and...
Old Mar 29, 2004 | 06:22 PM
SSS2000's Avatar
Default Bad compression numbers and...
I noticed smoke (oil) coming from my breather filter, so I did a compression test tonight. When I pulled the plugs I noticed an oil residue on the #2 & #3 plugs. Here are the compression test numbers...
185-70-70-185 This is a b18b. I guessing this is probably ringlands, right?
Please don't tell me this could be anything more than just rings...
Old Mar 29, 2004 | 07:14 PM
SSS2000's Avatar
Default Re: Bad compression numbers and... (MilanoRedLST)
anyone?
Old Mar 30, 2004 | 04:52 AM
SSS2000's Avatar
TTT...
Old Mar 30, 2004 | 05:20 AM
CivicSoul's Avatar
If you just did a hard pull and it happened, than yes, it is probably your ringlands. If it has been getting worse, it might be your valve seals?
Old Mar 30, 2004 | 06:16 AM
earl's Avatar
You really need to check that the cylinders did not become egg shaped or balooned out. You CANNOT do this by looking at them.
Old Mar 30, 2004 | 06:40 AM
Mad Cow's Avatar
Default Re: Bad compression numbers and... (earl)
What causes them to become out of round? What's the best way to check?
Old Mar 30, 2004 | 07:11 AM
SSS2000's Avatar
Default Re: Bad compression numbers and... (CivicSoul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSoul &raquo;</TD></TR><TR><TD CLASS="quote">If you just did a hard pull and it happened, than yes, it is probably your ringlands. If it has been getting worse, it might be your valve seals?</TD></TR></TABLE>
It has been pretty consistant...I'll probably take the head off this weekend when I have some time.
Can I check the shape of the cylinders with calipers?
Would it be wise to just buy a new block and drop in some forged pistons and rods?
Old Mar 30, 2004 | 12:50 PM
SSS2000's Avatar
How would I know if it was valve seals?
Old Mar 30, 2004 | 01:14 PM
earl's Avatar
Default Re: Bad compression numbers and... (MadCow)
Cylinders 2 & 3 always run hotter than 1 & 4. That is why problems like this show up there. You have to have a machine shop check your bore diameters. They need to be checked all down the bore.
Old Mar 30, 2004 | 02:08 PM
SSS2000's Avatar
thanks earl
Old Mar 30, 2004 | 02:41 PM
gunmetalcivic's Avatar
i had the same problem. smoke coming out and oil on #3 spark plug. it turned out to be a bad ring landing.
usdmblackcivic
Sep 4, 2010 11:56 PM
hondaeg8
10
Jul 25, 2004 11:13 AM
EF8_SiR
Jul 20, 2003 10:24 PM
Aeka GSR
Oct 4, 2002 11:44 PM
