bad bov
Old Mar 28, 2004 | 04:35 PM
iwhichisme's Avatar
Default bad bov
Just wandering what a bad bov would cause? Heres the situation, I have a greddy type s bov, and the screw on the top of it came out, causing me to not have any vaccum. When i capped off the peice of the hose that connected to the bov, the car ran fine after that. I did notice that before i was atlaest doing 4psi, but now it only shows like 2psi. Also, even thought the hose is capped off, the bov still flutters just a little when i get on it (this is at 2psi).
My issue is, that i figured that the car should run like normal with more psi even if the bov is non-functional, but i still cant make any boost and the bov still flutters a little. any help is appreciated.
Old Jun 14, 2004 | 08:05 PM
SOHC Gord's Avatar
Default Re: bad bov (iwhichisme)
get a new bov easiest solution
Hand_Fed
Apr 22, 2010 04:51 PM
mike93boost
May 29, 2006 07:39 PM
oemDC2
Dec 27, 2003 08:52 PM
wickedxboi
May 21, 2003 08:33 PM
