Backpressure question?
Old Feb 3, 2011 | 06:06 AM
Tracyrr's Avatar
Default Backpressure question?
This may be too vague but here goes.... All else being equal, which turbo will have less backpressure: Precision 6262 w/t3 .82 open exh housing or Precision 6765 w/t3 .82 divided exh housing? This is for my twin rear mount corvette.... It is a daily driver. Thanks guys p.s.... this forum has more info on these t3/t4 turbo's than any other forum i'm been on.... Mad Props to a great site!
Old Feb 3, 2011 | 07:33 AM
Tracyrr's Avatar
Default Re: Backpressure question?
well it looks like precision might not make a divided t3 housing for the 6765.... oh well....
Old Feb 3, 2011 | 08:14 AM
Casey's Avatar
you can get a divided housing for them.
as far as an answer to your question, the larger turbine is going to create less backpressure. honestly with your displacement, 2 6265 .82 open housing would be responsive and make stupid power.
Old Feb 3, 2011 | 10:03 AM
Tracyrr's Avatar
i currently have two 6262's but am running into higher backpressure when i crank the boost up which is why i was looking to upgrade the turbine side as well as the compressor side..... i should have bought 6265's to start with but spilled milk.... thanks
Old Feb 3, 2011 | 11:48 AM
W!d3b0dYr3X's Avatar
The divided housing will make ur back pressure worse. An open housing has a more efficient and less restrictive flow. The divider wall tends to be more restrictive due to the additional surface area that causes losses with turbine gas flow and is mainly used applications where engine rpm is not high for more torque in the low and mid range. I drive an 03 evolution which uses the divided twin scroll factory and it makes its power down low. I peaks around like 4k rpm. The best way you could fix the back pressure issue which kills power is to go to a t4 or bump up the size in the exhaust ar size.
Old Feb 3, 2011 | 11:51 AM
xenocron's Avatar
Precision just released a bad-*** 6466 billet which you might be interested in...
Give me a call and I'd be happy to help you out on this one.
Old Feb 3, 2011 | 11:53 AM
U could also opt for a larger inducer diameter on your exhaust wheel that reduces backpressure as well if u didn't want to swap turbos completely.
Old Feb 3, 2011 | 11:56 AM
Casey's Avatar
oh nice! yeah to the original poster, check into those.
xenocron, what other sizes have they recently released? i know that the were doing billet "gt" series turbos as well that havent been out too long
Old Feb 3, 2011 | 06:24 PM
DDTECH's Avatar
Borg warner would probably be a better choice now with their new turbos out..
Old Feb 4, 2011 | 10:00 AM
Tracyrr's Avatar
Thanks for the help guys!
Tracyrr's Avatar
I have not heard about these yet.... Thanks!
Old Feb 4, 2011 | 10:22 AM
Bugermass's Avatar
What power level are you at? whats your setup? I've seen over 800HP on twin 6262 T3 without issues on a vette.
Old Feb 4, 2011 | 10:44 AM
Tracyrr's Avatar
I'm not familiar with BW but i will look into the new turbo's.
I've done near 700rwhp at only 14 pounds with my old sts twin system... i just completed my new twin rear mounted system and it should put me right around 900rwhp at higher boost (22 - 23 pounds).... I'm guessing these turbo's would be pretty close to maxing out because of backpressure. I was looking to upgrade these 6262's t3 so i can hit the 1xxx+ rwhp mark! I know the 6765's will do it but i want to make sure it doesn't kill my drivability....
Great forum guys!
P.S.... i really admire what ya'll are able to get out of these little motors!!! I wish my V8 was near the efficiency ya'll run!! Big Props
Old Feb 4, 2011 | 11:31 AM
DDTECH's Avatar
Great forum guys!
i'm in baton rouge, if you need any help with anything or parts, lemme know my shop and I will help in anyway we can.
if your a vette guy you might know Mark b? with the white z06, on the dope and we know futral and all them..
Old Feb 4, 2011 | 11:48 AM
Tracyrr's Avatar
oh yes. I'm still learning the turbo stuff, thanks for the help! Geoff at engine power systems in baton rouge has done my tuning and dyno work. thanks tracy
Old Feb 4, 2011 | 01:19 PM
DDTECH's Avatar
@ EPS? We do some work with thunder and hope to work with GEOff in the future, he's right across the street from lightning.
Old Feb 4, 2011 | 01:25 PM
Tracyrr's Avatar
Yes, that's him.... i did see another shop across the street from EPS... ha ha small world.
Old Feb 5, 2011 | 08:52 AM
92cxturbo's Avatar
I would get with this guy. Knows his stuff and will lead you in the right direction.
sikid111
Sep 20, 2010 10:16 AM
manuel12
May 30, 2009 09:48 PM
1cpu
Jul 7, 2007 09:39 AM
gsrbruin
Jun 25, 2003 09:06 AM
hondaZvic
Nov 5, 2002 01:16 PM
