b20vtec turbo
Old Dec 12, 2007 | 10:10 AM
d16z6ef's Avatar
Default b20vtec turbo
have a stock jdm b20 with a b16 head gsr cams lovefab manifold and a precision sc61 turbo and more bolt ons im tuning it on neptune rpt on 10 lbs of boost i wanted to know if it was better to run it on c16 race gas im wanting to run like high 11's
Old Dec 12, 2007 | 10:42 AM
TayTeg91's Avatar
Default Re: b20vtec turbo (d16z6ef)
i don't suggest it
Old Dec 12, 2007 | 10:58 AM
d16z6ef's Avatar
why?????
Old Dec 12, 2007 | 11:11 AM
TayTeg91's Avatar
Default Re: (d16z6ef)
if your goal is 11 seconds...then running a stock b20 block isnt the best idea. your cylinder walls won't hold the power.
Old Dec 12, 2007 | 11:19 AM
quicksilver1689's Avatar
i ♥ snails
id get some arp rod bolts and keep it under 300whp and you should be fine. I wouldnt take it over 8k
Old Dec 12, 2007 | 11:22 AM
96 EX's Avatar
Default Re: (quicksilver1689)
If its a STOCK b20 bottom, I wouldnt take it anywhere past the redline of the b20. Just cause the head can hold 7500+ rpm's doesnt mean the b20 bottom can. One thing to remember is it was a truck engine and wasn't engineered for high rev's more for lowend torque.
Old Dec 12, 2007 | 11:26 AM
d16z6ef's Avatar
Default Re: (96 EX)
yeah i thought so
Old Dec 12, 2007 | 11:41 AM
i ♥ snails
get rod bolts then take it to 8k without problems
Old Dec 12, 2007 | 11:49 AM
Schister66's Avatar
Man U FTW
An SC61 is a bad turbo for a stock B20. It will not get close to its efficiency range because the B20 sleeves will let go after ~300whp. Get an LS block and try it...you might have better luck
Old Dec 12, 2007 | 12:10 PM
hellakapps's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">An SC61 is a bad turbo for a stock B20. It will not get close to its efficiency range because the B20 sleeves will let go after ~300whp. Get an LS block and try it...you might have better luck</TD></TR></TABLE>
agreed that's alot of turbo for a stock b20, if you do pistons and rods you'll be able to actally use the turbo, i'm using onne to get 500whp on pump and the b20 would not hold up to that
Old Dec 12, 2007 | 12:18 PM
Schister66's Avatar
Man U FTW
^^pistons and rods wont help on a stock B20...the sleeves are the weakpoint and would need to be addressed first. A piston/rod build on an LS would allow you to make upper 400s or low 500s on stock sleeves
DCtbunch
May 27, 2009 12:59 PM
96civicHB
Feb 11, 2008 06:41 PM
95 RED CIVIC
May 3, 2006 05:01 AM
PerfectXtreme
Aug 25, 2003 11:36 PM
baybeboi
Aug 4, 2002 09:19 PM
