B20's ok to Sleeve?
Old Jun 20, 2010 | 03:56 AM
EdSales's Avatar
Default B20's ok to Sleeve?
I want to build a B20Vtec Motor and push it for 500 WHP. I've read that when you Sleeve the B20, that they don't seal and coolant leaks into the crankcase. Any words on this?
Old Jun 20, 2010 | 04:21 AM
non-VTEC's Avatar
Default Re: B20's ok to Sleeve?
send it to golden eagle. they are the only ones who can sleeve a B20 right and can guarantee not coolant leaking.
Old Jun 20, 2010 | 05:20 AM
EdSales's Avatar
Right, but I read on another post where you said that makes the Engine run 15 degrees hotter...and while 15 degrees is no big deal, when I'm boosting its going to heat up a good bit.
Old Jun 20, 2010 | 06:28 AM
EdSales's Avatar
How much did it cost including Sleeves for Golden Eagle to do it?
Old Jun 20, 2010 | 06:51 AM
non-VTEC's Avatar
i believe they charge about 1k to do the B20. slightly less for a B16/B18. but you better call or email them to be sure. there are little to no machine shops who sill sleeve a B20 block with a warranty. GE is your only/best choice if you really want to use that block.
as for the heat....you need to do some cooling system upgrades regardless if it's boosted or not.
Old Jun 20, 2010 | 09:35 AM
89vwfox's Avatar
i talked to kingmotorsports they told me they do not recommend sleeving b20's due to the diff sleeve design compared to the superior ls guy who i talked to said he built 1 and it cracked a sleeve within 10,000 miles told me to get a ls and sleeve it.
Old Jun 20, 2010 | 02:56 PM
EdSales's Avatar
I'm pretty set on doing a B20 over an LS. A bunch of my friends did an LS and don't want to copy them. If Sleeving a B20 is going to give me nothing but problems, I'll just build an All-Motor B20Vtec or build a Boost B16A to 500 WHP.
Old Jun 20, 2010 | 03:37 PM
89vwfox's Avatar
King told me i should get an ls sleeve it and bore to 2.1 i would go with b16 or ls i used to be set on b20v allmotor but there sleeve design is totally diff from other b series motors and no matter what they will crack at some time stock or aftermarket. I think the b20 sleeve is one whole peice while the ls has individual sleeves someone correct me if im wrong not hating on your build
Old Jun 21, 2010 | 09:52 AM
TheShodan's Avatar
Moderator
There is a difference between Boring a B20 and Sleeving one. Remember, the sleeves from golden eagle are REPLACING the B20 sleeves entirely. I'm not sure you heard the advice King gave you, but you might be a little confused.
Sleeving a B20 Block is just fine, and would do quite well with the B20 crank and B16 head. I personally have run Golden Eagle since 2001 and still have the car today. wonderful stuff.
Old Jun 21, 2010 | 10:15 AM
EdSales's Avatar
If you say its good to run Shodan, then my worries are put to rest. Thanks.
Old Jun 21, 2010 | 10:18 AM
89vwfox's Avatar
They did tell me alot of stuff on the phone i dont know if they where trying to sell me out on one of there builds or what. But they did tell me for a fact that they do not recommend resleeving b20 blocks to there customers. And the part i might not have understood....the b20 sleeve design is one whole piece making it weaker and restricting coolant flow with stock or aftermarket sleeves. and the ls sleeve design are individual pieces(4)after market or stock making them stronger and allowing for better coolant flow???sounds kinda right idk i wish someone could verify this 100%
Old Jun 21, 2010 | 10:22 AM
EdSales's Avatar
I saw someone on here sleeve a B20 with LS Sleeves. It sounded like a bad idea when I clicked on the link, and the pics didn't look good to me.
Old Jun 21, 2010 | 10:27 AM
89vwfox's Avatar
http://www.ht-archive.com/showthread.php?t=709410
Old Jun 21, 2010 | 10:33 AM
89vwfox's Avatar
I think what im trying to say is b20 sleeves are more prone to sinking or cracking due to the one piece design even with after market sleeves the motor will be strong but a sleeved 2.0 ls will be stronger due to sleeve design
Old Jun 21, 2010 | 10:38 AM
EdSales's Avatar
I'm still stuck on whether or not to go with my orginal goal of a 500 WHP FI B20Vtec, or go with the All-Motor B20Vtec and pull out my B16A to build to 500 WHP.
Old Jun 21, 2010 | 11:14 AM
vwbased's Avatar
have a nice day
Old Jun 21, 2010 | 11:45 AM
TheShodan's Avatar
Moderator
Hmm.. very informative indeed. thank you.
Old Jun 22, 2010 | 06:25 AM
PRO1's Avatar
i would never send a b20 off to get sleeved, wat a waste, Why doint u just get b16 or GSR? or LS ? not that hard, Why risk a 1k ? all for a b20? Get a LS block
Old Jun 22, 2010 | 07:36 AM
TheShodan's Avatar
Moderator
Perhaps he wants a true 2.0 Litre and this is what is available to him. having the GSR or LS sleeved to 84mm with an LS crank is more practical to get to the 2.0 litre displacement.
Old Jun 22, 2010 | 07:47 AM
dana h's Avatar
kjoihobilyli88tttttttttttttt
boostedb20ek
Dec 17, 2013 03:48 AM
Del Sol
Mar 3, 2013 12:39 PM
blackeg
Aug 9, 2008 03:06 PM
stockmr2
Mar 9, 2006 12:51 PM
-KangaRod-
Jun 24, 2004 02:29 PM
