B20b turbo setup!
Old Apr 18, 2013 | 07:50 PM
sw20 ant's Avatar
Default B20b turbo setup!
New to all this Fwd stuff and honda's haha, Anyways I picked up a 91 Integra and I picked up a b20b from my engine guy who I buy my Sr20's from and pretty much any engine for that matter. car runs good and all that but I'm use to having a turbo under my hood so yea haha.
So here is my quick run down of parts I'm going to throw at the b20 and let me know what you guys think. This isn't a Dream build list that has mugen everything and hks this, greddy that haha. Just a budget mild power build! Pics to come
B20b 49,000 miles according to the cluster
-T28 turbo from a S14 Sr20 engine (ball bearing) (It has an Hks actuator On It from one of my old setups I had set up 16 psi)
-Log manifold
- Ngk BKr7e plugs and all oem cap,rotor,wires (already installed minus plugs)
-Walbro 255lph
-rx7 t2 555cc injectors ( I have 2 sets from previous rx7's I've owned)
-I have a relativley small FMIC core that I used on one of my sr20's and It made perfect power and minimal lag for the size turbo I'm using.
-Oem timing belt,water pump
-Ported throttle body (quicker throttle response)
-I already Installed a b18 Intake manifold
-I'm going to have it chipped on street tuning by road race engineering
-clutch masters 6 puck clutch and fidanza flywheel (or XTD because my wallet might not be able to hang right now.
Ok well I'm looking for anywhere between 220-250 whp. Not sure It It's possible on a non vtec head but i know on a sr20 this is 260+rwhp all day long. Like I said not looking for crazy power just want something with some pep! I already have half the parts like the turbo,pump,injectors
Old Apr 18, 2013 | 07:56 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: B20b turbo setup!
that setup is very doable! b20 seem to fail at around 300+, the sleeve design is different from the other b series for some reason.
Old Apr 18, 2013 | 08:38 PM
sw20 ant's Avatar
Thanks for the input! i was just reading that right now actually and hopefully i'll be good at my power level. I'm hoping to be in the 240whp range but 260 would be nice haha, anything over 200whp is fine with me honestly. That will be fun enough for a daily driver and reliable with the right tune and wont be a high stress engine!
I like your N.A.T.O and N.F.C funny! i'm down for both of those clubs hahaha
Old Apr 18, 2013 | 08:52 PM
haha thanks
hopefully youll have a good tq range as well as your whp
keep us posted
Old Apr 18, 2013 | 09:54 PM
yungkhmer's Avatar
good luck. im aiming for 300whp on my b20z block with devils own meth injection.
Old Apr 18, 2013 | 11:40 PM
sw20 ant's Avatar
haha thanks
keep us posted
I'm hoping that also!! with the t28 I'll hopefully have a fat torque powerband! I'll be done by the begining of next month and have the pics up and tuning video!
Thanks! The meth should get you there with that higher compression ratio and boost! If I had the money I would definatley get meth injection to help keep detonation in check! Good luck to you also!
Old Apr 19, 2013 | 04:11 AM
Steveeghatch's Avatar
its very duable i had a 99 b20b, t3 60trim, 450cc , sk2 IM, 2-1/4 exaust and had 254whp at 8psi
Old May 23, 2013 | 05:51 PM
sw20 ant's Avatar
Couple updates on this and If I can find my Sd card to my camera some pictures!
Delayed the whole turbo process to make the car safe for any kind of power, All new suspension, rebuilt rack n pinion, fresh hawk brake pads and brembo blank rotors etc etc etc.
next weekend i'm going to throw the setup on the car and take it to get tuned with a video and dyno with video. 250whp crossing my fingers!!!! Going to have to take it easy on this A1 4.4 cable trans or else
Old May 23, 2013 | 05:53 PM
sw20 ant's Avatar
I'm hoping, I looked into skunk2 intake manifold but that will have to wait. My engine is a b20b4 so it's the low compression. how long did yours last at the power?
Old May 23, 2013 | 06:22 PM
v8eatrr's Avatar
You won't make near that power with that turbo
Had a Nissan t28 and it made less then my eBay .63 housing on my b20b
Old May 23, 2013 | 09:23 PM
sw20 ant's Avatar
I made 270+rwhp on a Nissan t28 with a couple of my sr20's. my last sr20 setup I made 292 rwhp @ 16 psi on this same exact t28 I'm going to be using and have since had it rebuilt. bone stock head/block, stock turbo manifold. b20 can't be different than sr20. the sr20 head isn't a great flowing head so I'm sure the b20 can make similar power, this power was done on a s13 red top so vtc can't be brought up here.
Old May 24, 2013 | 12:47 AM
sw20 ant's Avatar
maybe you had a t25 and thought u had a t28. t28's easily push 200 with zero issues, a simple boost increase on a stock sr20 with the t25 puts you in 200whp range without bolt ons.
forgot to add that my t28 is a pulsar gtir super .60 with s14 t28 compressor housing. turbo setup is maxed out at 320whp. lil Nissan trick we use to say we have stock turbos hahaha, like the evo guys and they're "stock" Ported to hell and compressor housing swapped 20g turbos.
Old May 25, 2013 | 03:02 AM
yungkhmer's Avatar
pick up a gsr oil/water pump.
Old May 25, 2013 | 05:25 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
There is so much bad advice and wront information in this thread it is pathetic.
OP - Stop comparing a different platform to another, it shows ignorance. Mugen, HKS, and Greddy parts aren't even talked about anymore. There have been better solutions and advances that are now preferred for the Honda platform. The B20 sleeves are not necessarily weaker when it comes to power, but there threshold for detonation and temperature is much lower than ANY other B series. Keep this in mind when you have somebody tune the car.
Your power goals should be easily reached and your list looks decent for a budget hodge podge build.
Old May 25, 2013 | 06:08 PM
TheShodan's Avatar
Moderator
Originally Posted by SiRCiviC94
And shim it :p
Do NOT do that to the GS-R/TypeR oil pump, please.
Old May 27, 2013 | 04:28 AM
it lasted 1 year because i changed for a miniram, also put a TIAL 38mm WG with 12psi spring and did not get it retuned and i blew 2 sleeves but still did 12.6 at the 1/4mile with cracked sleeves
druidesque
Apr 19, 2010 09:56 AM
V8 Eater
Dec 24, 2008 01:19 PM
eddie5141981
Aug 8, 2008 02:45 PM
B20turbo85
Dec 18, 2006 05:08 PM
chuckles2
Mar 13, 2005 01:22 AM
