B20/VTEC with an SC50
Old Nov 16, 2003 | 12:47 PM
*Boostwerks*'s Avatar
Default B20/VTEC with an SC50
Well I'm thinking about keeping my SC50 instead of selling it with the rest of my crap, and just throwing that on (hopefully) a B20/VTEC swap.
It's a 50 trim with the .63ar turbine.
The motor will be built, and I'd like to get around 400hp out of it on race gas.
Should I keep it, or sell it and buy something a little bigger...SC34?
Thanks guys
Bryson
Old Nov 16, 2003 | 01:15 PM
Seraph0's Avatar
Default Re: B20/VTEC with an SC50 (Bryson)
I'm building a 2.0L GS-R and I will be using a variant of a .50-trim wheel.
Old Nov 16, 2003 | 02:44 PM
PWRVTEC's Avatar
Default Re: B20/VTEC with an SC50 (MarkC)
I am using a SC54 on my 2.0L LSVTEC built and I wish I had went bigger for more lag. I have 10lbs at 4800 and I am almost to the 400whp mark at 10lbs
Old Nov 16, 2003 | 03:21 PM
baphomet's Avatar
Default Re: B20/VTEC with an SC50 (PWRVTEC)
Get something bigger.
On a side note, does the b20 block have the same stroke as a b18b?
Old Nov 16, 2003 | 04:10 PM
liam821's Avatar
Default Re: B20/VTEC with an SC50 (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">Get something bigger.
On a side note, does the b20 block have the same stroke as a b18b?</TD></TR></TABLE>
Yes
Old Nov 16, 2003 | 04:11 PM
baphomet's Avatar
Default Re: B20/VTEC with an SC50 (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
thanks
liam821's Avatar
Precision says the SC50 is good for 450hp. So if your goal is around 400whp you should be ok.
Anyways...you can always use the SC50 for awhile and then sell it later. They are easy to sell here on honda-tech.
liam
Yeah thats what I'm thinking.
This turbo was Gigantic on my ZC, but for the B20 I think it will spool a little too fast...Especially with a B16 tranny.
I'll most likely go all out with the SC61...I'm sure it will spool nicely with a 85mm bore.
calishowa
Oct 12, 2008 11:54 PM
hondachris1994
Mar 24, 2006 07:18 AM
96LsBang
Jan 10, 2006 09:07 AM
roycivic92
27
Dec 12, 2004 12:33 PM
civic5483
31
Mar 7, 2004 11:13 AM
