B20/Vtec 1/4 Mile Times *RAN AT TRACK!*
Old 06-15-2002, 09:04 PM
djdxm's Avatar
Default B20/Vtec 1/4 Mile Times *RAN AT TRACK!*
Well I finally ran my car at the track. There is a pic of it all squatted down gettin ready to haul *** . Anyways Liam and I modified the fuel system, 63psi of fuel pressure, and -35% on VAFC hack. I was able to boost 10psi and made a best run of 13.08 @ 113.30
My Time Slip
React: .677
60ft: 2.252
330: 5.894
1/8: 8.708
1/4: 13.083
MPH: 113.30
That was my best all day after 6 runs. Was very consistenly running low 13's. Was hoping to break into the 12's but it spun the tires all the way though 3rd. I am sure with some slicks it would of easily laid down a mid 12.
Anyways Thought I would show everybody that the VAFC hack works quite well. I haven't seen many ppl posting times with it so here ya go.
My setup is a built b20/vtec w/ T3/T04E, greddy intercooler.
Late
-jay
[Modified by djdxm, 6:04 AM 6/16/2002]
Old 06-15-2002, 09:09 PM
KC GSR's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (djdxm)
I'm a noob and i'll admit it...but can someone please inform me what vafc "hack" is all about??
btw, nice times man
[Modified by KC GSR, 6:09 AM 6/16/2002]
Old 06-15-2002, 09:11 PM
M.A.R.C.'s Avatar
you rock jay... good run.
Old 06-15-2002, 09:13 PM
Ri5e's Avatar
Nice sleeeper.
That is faaast, 13 seconds with STREET TIRES. Not bad
Also, what kind of injectors/fuel pump are you utilizing? And was this with Pump gas?
What kind of pistons/rods are you using?
[Modified by BG Boost, 6:13 AM 6/16/2002]
Old 06-15-2002, 09:15 PM
Better than steak
Arturbo's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (BG Boost)
113mph!!
art
Old 06-15-2002, 09:18 PM
djdxm's Avatar
Nice sleeeper.
DSM 450's, homemade resister box, B&M FPR (shitty) w/ 63psi I have a walbro 255HP in-tank.. Yup 91 octane.
Eagle/Endyn Rollerwave's
-jay
[Modified by djdxm, 6:19 AM 6/16/2002]
[Modified by djdxm, 6:20 AM 6/16/2002]
Old 06-15-2002, 09:20 PM
M.A.R.C.'s Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (KC GSR)
btw, nice times man
Depends. The VAFC hack DJDXM is talking about involves using a VAFC and bigger injectors (and the supporting accesories... ie fuel pump) to control fuel for boost. The best way to show you how it works is to go to http://www.thedropshop.tv/vafc.htm
Old 06-15-2002, 09:27 PM
DLB1994's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (Arturbo)
113mph!!
art
113mph can get u in the high 11s
Old 06-15-2002, 09:36 PM
djdxm's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (DLB1994)
That would be sweet also didn't unbolt my exhaust. Does that make that much of a difference? i have open atmosphere dump, but a max-rev 2.5" downpipe, test pipe and a tanabe g-power exhaust or whatever it is. but i know its 2.5"
-jay
Old 06-15-2002, 10:16 PM
Markaccord95's Avatar
good one slutomus prime
Old 06-15-2002, 10:35 PM
SiRkid's Avatar
hmmmmmmmmm
Old 06-15-2002, 11:05 PM
bQQsted hybrid's Avatar
113mph!!
art
I was thinking the same exact thing. With proper traction, you should be able to get a much better time BTW Where is that track? It looks like ****.
Old 06-15-2002, 11:10 PM
MugenSi00's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (bQQsted hybrid)
why only 10psi? Turn up that boost!
Once my fully built b20vtec swap is done, I'll be running daily 15psi.
Is your block sleeved? Have any head work?
Old 06-15-2002, 11:12 PM
BoostinDC2's Avatar
nice job. with some slicks the times should be killer
Old 06-15-2002, 11:21 PM
Sonny's Avatar
113mph
Sonny
Old 06-15-2002, 11:36 PM
-=TWITCH=-'s Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (Sonny)
dizzzzzam wish I was that fast!
Old 06-16-2002, 12:20 AM
Paul Walker's Avatar
113mph!!
art
That's Carlsbad raceway...
[Modified by Paul Walker, 2:06 AM 6/16/2002]
Old 06-16-2002, 01:01 AM
djdxm's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (MugenSi00)
I need better fuel management. I cannot run more boost with the VAFC hack I am pushing 10 to 10.5psi out of it before it throws codes. I am going to get a hondata with some 750cc injectors, (or bigger) and going to try to get about 14-15psi out of it w/ pump gas. And push more on race gas. Some of my friends are making 450-475whp outta theres around 20psi.
This was the cars first outting, and I wanted to see what it could do under its current setup. I was quite impressed, but very tempted to go back and do it again with a set of slicks. I would love to throw down a low 12.
-jay
[Modified by djdxm, 10:01 AM 6/16/2002]
Old 06-16-2002, 03:23 AM
inspyral's Avatar
Old 06-16-2002, 08:28 AM
quikB18B's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (inspyral)
mph 113 You make me anxious now for next friday's visit to the track. I ordered my drag radials few days ago so ill be ready to go. oh btw is this on stock bottom end? because im running same setup but im scared to go past 6.5psi my fuel is similar to yours also I have 60 psi fuel pressure, walbro intank but i am running 310cc injectors with vafc, but hondata coming soon so ill be ditching the 310 for proly some 550cc. Good run though
Old 06-16-2002, 08:36 AM
djdxm's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (quikb20)
Its a built bottom end. I am just waiting to get a little better fuel management and run 14+ psi.
I might be at the track this next weekend with a set of slicks.. 22x8 MT's... gonna see what i can pull with some traction and the same setup
Good luck with yours.
-jay
Old 06-16-2002, 08:47 AM
Finest's Avatar
Built as in resleeved? Stock B20 bore, I assume?
Anyways, great MPH. Was this on full interior too, or no?
Old 06-16-2002, 08:54 AM
djdxm's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (Prelude_RCR)
Its stock sleeves, 84.5MM Endyn rollerwave's, eagle rods. Tryin to see what i can pull outta the stock b20 sleeves since they are alot thicker then my b16 sleeves were.
I removed the rear seat and my sub box and stuff in my trunk. Other than that it was full interior. Also had full exhaust. 2.5" tanabe a test pipe though.
-jay
[Modified by djdxm, 5:54 PM 6/16/2002]
Old 06-16-2002, 10:54 AM
done's Avatar
113mph!!
art
thats what i was thinking... 13s is a bit slow, i know that car has alot more then that 11s is more like it
hondata is god
[Modified by Jordo, 1:56 PM 6/16/2002]
Old 06-16-2002, 11:06 AM
CovertFI's Avatar
Default Re: B20/Vtec 1/4 Mile Times *RAN AT TRACK!* (Jordo)
can you run ac with the b20, are you running ac with it? kick *** car
Quick Reply: B20/Vtec 1/4 Mile Times *RAN AT TRACK!*
