b20 turbo need help or ideas
Old Oct 10, 2010 | 03:51 PM
Jdmefsir12's Avatar
Default b20 turbo need help or ideas
hey wats up i have a b20b with a t3 t4 57trim turbo 550cc rc injectors walbro 255 fuel pump fuel reg but its tuned on 8 pounds on 440cc
so my problem is that is lags really really bad at 3200 to like 3900 like doesnt want to go then once it goes passed it then it starts to go but dont know wats going on with it any answers will help thanks
Old Oct 10, 2010 | 03:55 PM
Gunmetal_B20_Hatch's Avatar
Default Re: b20 turbo need help or ideas
fix your tune... OMG
Old Oct 10, 2010 | 06:08 PM
TheShodan's Avatar
Moderator
Is it tuned? management? check for leaks in the intercooler, couplers and intake. Need more to go on here.
Old Oct 10, 2010 | 10:54 PM
Jdmefsir12's Avatar
the car is tuned on p28 on chrome.. but like i said thats tuned on stock fuel reg and stock fuel pump and on 440cc now its on 550cc rc walbro fuel pump 255 and fuel reg checked all leaks everything everything good
Old Oct 10, 2010 | 10:57 PM
TheShodan's Avatar
Moderator
So you used a pressure tester to check all the vaccuum leaks at the inlet of the turbo
Old Oct 10, 2010 | 11:02 PM
Jdmefsir12's Avatar
OH NAW JUST CHECKED ALL THE COUPLERS AND CLAMPS
Old Oct 11, 2010 | 07:38 AM
trujdmek's Avatar
you need to get tuned again if the car was tuned without a fuel pressure regulator and bigger injectors its going to fun different with those new components installed... more likely than not its running very rich in which case you need to go on the dyno again and retune the car... good thing for you is the car should drive and be more reliable on the new setup then the old one
Old Oct 12, 2010 | 10:04 PM
b20ricepower's Avatar
TUUUUNEEEEE!! Its that simple it will never run right until you retune it
Old Oct 13, 2010 | 09:27 AM
BETOSCOUPE's Avatar
Who tuned it?
Old Oct 13, 2010 | 09:35 AM
2k.civic.si's Avatar
so you greatly increased your fuel flow and didnt think you would need to retune?
Old Oct 13, 2010 | 01:12 PM
EsotericImage's Avatar
Retired Moderator
THIS
Anytime your AFR changes you need to retune it..
As far as the lag, is it a .63 or .48 57 trim?
Old Oct 13, 2010 | 02:26 PM
Jdmefsir12's Avatar
no ones tuned the car on the new set up yet.... but laster person who had the car before me had small injectors stock fuel pump stock reg and rail.... i upgraded injectors fuel pump fuel reg and rail.....
all i know is the turbo is 57 trim t3 t4 turbo .63
and also i know it needs a tune.. just wanted to ask wat people thought..
and also how much power u think it will make
Old Oct 13, 2010 | 03:02 PM
Retired Moderator
personally, i wouldnt use a .63 on a stock block. It spools late like you said and B20's dont rev high anyways. Just change the back housing to a .48 and youll spool faster/quicker.
as far as how much power.. anywhere from 180-225 is my opinion.. theres too much not listed to give a def answer.
Old Oct 14, 2010 | 03:19 PM
Jdmefsir12's Avatar
well i think it will make more then that.... i had a all motor with all oem parts make 190 tuned
but i was told it could easy make 300 on 10 pounds...
Old Oct 14, 2010 | 03:22 PM
Jdmefsir12's Avatar
well its a b20b b16a2 trans 6 puck clutch stage 3 pressure plate 11.5 clutchmaster flywheel 550cc rc injectors aem fuel rail aem fuel reg walbro 255 fuel pump full turbo kit t3 t4 57trim on chrome
Old Oct 14, 2010 | 03:23 PM
Jdmefsir12's Avatar
its not a lag like turbo lag feels like fuel cut
Old Oct 14, 2010 | 06:46 PM
PyroProblem's Avatar
Your tuned for 440cc injectors, but your running 550's...This would be the first thing I would look into. A retune is needed.
Old Oct 16, 2010 | 11:47 AM
Jdmefsir12's Avatar
ttt
Old Oct 16, 2010 | 11:53 AM
Retired Moderator
This ^
you might make 300 realisticy, but IMO its a ticking time bomb on that bottom end. I wouldnt put the bottom past 300 @ crank. But what is the torque range? thats what you need to be looking at.
B0Z0
10
Jan 13, 2011 09:36 AM
2kgsrt
Apr 1, 2010 06:25 PM
90civicgsr
Feb 7, 2008 06:17 AM
rexthermal1
Oct 9, 2005 12:00 PM
