B20 head on a LS-T?
ok heres my problem, im building a ls-T and have the chance to get a jdm b20 head, i dont know if its the rare p8r but it is for sure jdm. now my question is, what would be the advantages/disadvatanges or can i even use it at all? thanks in advance..
Yeah, except you'll still have the same power limit as before. In other words, lower CR on a built engine just gives you a bit more tuning leeway and slightly longer spoolup due to the engine not being as effecient.
I hope you're doing it because you either don't have an LS head, or you're getting the b20 head for free. The difference honestly is like the diff between choosing a z6 or y8 head for a mini-me. Use whats cheapest to save up for cams or vtec.
ok so i uderstand this 100%
with a lower comp ratio it will take longer to spool
im running i t3 t4 .63 ar
stock ls motor rebuilt with new honda parts oem bearing etc.
i have no head for it but i can get a jdm b20 head intake manifold and throttle body for 120.00.
so my next ques is if i get that head i want to get it hot tanked and shaved to help spool time?? opinons please
the p8r will not work unless ur bottom end is a 2.0 or 84mm bottom end. The p8r head has bigger valves like vtec and chambers open to 84mm. So no it wont work unless u have a 2.0 LS bottom end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMLS4dr200whp »</TD></TR><TR><TD CLASS="quote">the p8r will not work unless ur bottom end is a 2.0 or 84mm bottom end. The p8r head has bigger valves like vtec and chambers open to 84mm. So no it wont work unless u have a 2.0 LS bottom end </TD></TR></TABLE>
He Speaks The Truth
He Speaks The Truth
hybrid_vtec
20
Apr 21, 2010 10:22 AM
