B20 bottom W/ B18 VTEC Head BOOST
Old Mar 19, 2023 | 10:31 PM
Guts's Avatar
Default B20 bottom W/ B18 VTEC Head BOOST
I just got an ek9 and I have no idea how much boost I can run with that setup, can someone give me a ball park on how much boost I can dish out with stock internals without blowing up, and how much power can I expect?
Thanks!
Old Mar 20, 2023 | 05:48 AM
TheShodan's Avatar
Moderator
Default Re: B20 bottom W/ B18 VTEC Head BOOST
Welcome to H-T! This topic has really been exhaustively covered for about the last 10 to 15 years, so please take a look via Google, (and not the H-T Search engine) for specific details on how-to's or specific details. (some links are a little old, but the science behind them hasn't really changed).. The amount of boost pressure is not the issue when it comes to this particular hybrid creation, but the amount of HP and airflow conversion that the engine will experience. Because of the slightly thinner walls of the B20 as compared to the B18 series of engines (if you intend to not change the internal components of the engine block. So, about no more than 300whp (or about 225kw to the wheels). The cylinder walls could easily become damaged after this HP level, or if you're over 2.5PRs using the smaller turbochargers. So, it depends upon what you'd rather do with this engine block. In addition, tuning management (both equipment and tuner) will be key in keeping your car running properly. This includes but is not limited to; Larger fuel injectors, fuel pump, Fuel pressure regulator, exhaust system, exhaust manifold, downpipe, etc).
Giving more information regarding your purpose of the car, what you've picked up so far, mileage (condition) of the long block, will be helpful. Also, where you're located in the U.S. would help so as to refer you to places that might be within your area. So take a look first, and then make another post with multiple questions and not create a bunch of threads.
Good luck, Guts, and welcome.
Old Mar 20, 2023 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Thanks!
One PSI Less than what breaks the engine.
Old Mar 21, 2023 | 04:06 AM
Chance EG's Avatar
Old Mar 21, 2023 | 05:43 AM
Stopsign32v's Avatar
Loved
Thanks!
To answer your question the motor isn't boost limited. Reason being is 10psi out of a T25 turbo will not be the same amount of air (power) as 10psi out of a T70 size turbo. You need to focus your concern on how much POWER your motor can handle without "blowing up". I know B20s have weak cylinder walls but I don't know where they crack. Basically you need to understand your motor's most likely weakest link and find out roughly where it will fail. That is your answer.
Old Mar 21, 2023 | 06:01 AM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Ive pushed a b20 with phk pistons to about 300whp for a long time. Spun a rod after raising the rev limiter past 7300 rpm. You cant spin them past that.
Rex-2000
Dec 3, 2014 04:35 PM
93grayeg
12
Sep 7, 2009 07:26 AM
93grayeg
Sep 2, 2009 08:45 PM
poormans_typer69
Aug 29, 2007 06:00 PM
