B20 and boost...
Old Sep 29, 2003 | 07:20 PM
xstalkrx's Avatar
Default B20 and boost...
How good is the B20 for turbo? Is the GSR engine a better selection for turbo?
Also...if I were to swap in a B20 into my GSR, aren't the redlines of the two engines going to be different? How do I get some B20 RPM gauges put in so I know when I hit redline. Thanks.
Old Sep 30, 2003 | 08:24 PM
b20turboic's Avatar
Default Re: B20 and boost... (xstalkrx)
love my b20 turbo no vtec head or anything but takes boost like a ***** and still ticking stock everything and 12 psi lol
Old Sep 30, 2003 | 08:35 PM
highmilehatch's Avatar
If you already have a gsr engine stick with that. You could still use the gsr tachometer even if you are running a different engine. Your rev limit would obviosly not be what a gsr's is.
Old Oct 1, 2003 | 08:02 AM
boosted eg's Avatar
Default Re: B20 and boost... (highmilehatch)
i agree if u have a gsr already stick with it the cylinder walls are alot stronger
Old Oct 1, 2003 | 08:58 AM
UNDER PRESSURE's Avatar
Default Re: B20 and boost... (boosted eg)
I'll second that, unless your going to sleeve it.
Old Oct 1, 2003 | 09:05 AM
Ri5e's Avatar
Default Re: B20 and boost... (UNDER PRESSURE)
b20 walls are weak...from experience
Old Oct 1, 2003 | 11:25 AM
Full-Race Henry's Avatar
it depends on what you are trying to do. if you want to build it or if you just want to use stock internals. If you want stock internals, then use the gsr, but if you are going to build it, then sell the gsr, buy a b20, sleeve it and get a vtec head.
Old Oct 1, 2003 | 02:22 PM
project dc2's Avatar
Default Re: B20 and boost... (CRV Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRV Monster &raquo;</TD></TR><TR><TD CLASS="quote">b20 walls are weak...from experience </TD></TR></TABLE>
care to shar eyour experience ? looks like you're running VERY VERY lean downlow .. is it tuned with hondata etcc ? fuel management? set up? i run 14 psi on mien, 262 WHP nd 254 torque .. been driving a while so far wit no problems
Old Oct 1, 2003 | 02:33 PM
91tegrals's Avatar
damn you made close too 280 on a stock ls or is it built...
Old Oct 1, 2003 | 06:00 PM
Default Re: (91tegrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">damn you made close too 280 on a stock ls or is it built...</TD></TR></TABLE>
if you're referring to me its STOCKK blOKKkK
viet1337
Apr 10, 2007 09:51 PM
Part1
Jan 29, 2005 09:24 AM
bonestock92si
Aug 20, 2004 06:42 AM
l3owen
Feb 7, 2004 11:13 AM
l3owen
Feb 7, 2004 08:17 AM
