b18c1 headwork
Old Dec 15, 2001 | 08:45 PM
downpipe's Avatar
Default b18c1 headwork
how necessary are these upgrades running 15-20lbs boost ona built bottom end - port and polish, oversized valves, springs retainers. etc? worth it, or overkill? (i'll have the head off anway...)
Old Dec 15, 2001 | 09:34 PM
bigTom's Avatar
Default Re: b18c1 headwork (downpipe)
none are NECCESARY, but i would at least go with springs/retainers and valves... its up 2 u though
Old Dec 16, 2001 | 08:54 AM
ekb18c's Avatar
Default Re: b18c1 headwork (Tom)
You can run stock head with built bottom end. However you may get more power of the motor if you have the head ported. When a head is ported you are allowing more air to travel at a faster rate. More air, more fuel, more spark = more combustion. Which in turns makes more power.
Old Dec 16, 2001 | 01:01 PM
downpipe's Avatar
Default Re: b18c1 headwork (ekb18c)
yes, but what about the srtuctural integrity of the stock head components? that is really my main concern.
Old Dec 16, 2001 | 08:43 PM
ekb18c's Avatar
if your going to get the head ported might as well change the springs, retainers etc. Better to be safe then sorry.
Old Dec 17, 2001 | 02:35 AM
downpipe's Avatar
Old Dec 17, 2001 | 04:30 AM
98Psi ITR's Avatar
how old is the head?
Old Dec 17, 2001 | 08:45 AM
downpipe's Avatar
Default Re: b18c1 headwork (98Psi ITR)
100,000 miles old. last 10,000 were turboed. then piston #4 said ..."good-bye, nice knowing ya..."
but i wonder, could there be any other reason besides a melted piston or broken ring lands causing 50% loss during leakdown test - coming out my valve cover? pffffffffffffffffff
Old Dec 17, 2001 | 08:53 AM
98Psi ITR's Avatar
bent valve or seat, valve stem seals or guides.
That's a lot of stress on an older stock head.
Old Dec 17, 2001 | 10:13 AM
Arturbo's Avatar
Better than steak
25 Year Member
Here is a dyno with a built motor and stock head. I want to say it was at 15psi, but it just may have been at 19psi.
His setup if I remember correctly was:
Drag 3 turbo kit
Thermal 3"
VFAC
RC 370cc injectors
Cartech FMU(set at 6:1)
cam gears
sleaved benson block with 9:1 CR
Stock head
Old Dec 17, 2001 | 10:19 AM
DIRep972's Avatar
Smarter than you
Default Re: b18c1 headwork (Arturbo)
hey that was Drag3GSR's dyno.. cam gears and VAFC are fun
delsol8017
Jan 1, 2009 11:01 AM
standbackimapro
Aug 31, 2006 07:25 PM
b18c5EF9
Aug 13, 2006 12:24 PM
b18sihatch
Jul 12, 2006 11:04 AM
Trak_Day
Dec 29, 2003 10:49 PM
