b18c1 block
Old Jul 13, 2006 | 04:22 AM
gsr336's Avatar
Default b18c1 block
i want to build my block up but im not sure what set up should i use? i want to bore it out but dont know how much and what pistons and rods and crank should i use? and what comp. ratio ?? aiming for atleast 400-500whp any suggestions?
Old Jul 13, 2006 | 06:03 AM
sp00led's Avatar
Default Re: b18c1 block (gsr336)
If you are unsure about what all to use you might want to look into having a professional make recommendations and build the motor for you. Lasky Racing (Earl) or RLZ Engineering are both great well known engine builders. Search and you will find plenty of info about them on this forum.
Old Jul 13, 2006 | 07:18 AM
QuarterMileMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr336 &raquo;</TD></TR><TR><TD CLASS="quote">i want to build my block up but im not sure what set up should i use? i want to bore it out but dont know how much and what pistons and rods and crank should i use? and what comp. ratio ?? aiming for atleast 400-500whp any suggestions?</TD></TR></TABLE>
How much money are you wanting to spend?? cuz that obviously determines what all you'll be able to do.
Old Jul 13, 2006 | 07:36 AM
gsr336's Avatar
well right now money isnt a factor it will just take time... but i want to atleast be boostin 25-30lbs i would go to one of these tuning shops around here but they're bullshiters
Old Jul 13, 2006 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr336 &raquo;</TD></TR><TR><TD CLASS="quote">well right now money isnt a factor it will just take time... but i want to atleast be boostin 25-30lbs i would go to one of these tuning shops around here but they're bullshiters</TD></TR></TABLE>
I see. Well since money isn't an option at the moment Here's what I'd do:
Sleeve to 85mm (to reach ~2.0L of displacement)
Weisco 8.8:1 Pistons
Pauter Rods
Stock Crank Micropolished and Balanced or ITR Crank
Old Jul 13, 2006 | 09:37 AM
4rc-fed's Avatar
Default Re: b18c1 block (QuarterMileMaster)
Save some just in case room.
83mm
Old Jul 13, 2006 | 10:57 AM
gsr336's Avatar
so going after market with the crank isnt better?
Old Jul 13, 2006 | 10:59 AM
nebulight's Avatar
Default Re: b18c1 block (4rc-fed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rc-fed &raquo;</TD></TR><TR><TD CLASS="quote">Save some just in case room.
83mm </TD></TR></TABLE>
Old Jul 13, 2006 | 11:25 AM
Makdaddynuge's Avatar
no just stick with stock crank, just micropolish and balance it, and i'd go with a little higher compression than 8.8:1...more like 9.2:1-9.5:1
Old Jul 13, 2006 | 12:00 PM
gsr336's Avatar
who would you recremend to do micropolish and balance for me? or just any machine shop would do?
Old Jul 13, 2006 | 12:04 PM
nebulight's Avatar
Just send your block to earl at Lasky Racing, they'll do it all.
Old Jul 14, 2006 | 05:54 AM
sp00led's Avatar
Default Re: b18c1 block (nebulight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight &raquo;</TD></TR><TR><TD CLASS="quote">Just send your block to earl at Lasky Racing, they'll do it all.</TD></TR></TABLE>
I'll second that. This is coming from personal experience as he built my block this past spring. Laskey Racing has GREAT customer service!
Old Jul 14, 2006 | 06:43 AM
Danny_EJ's Avatar
Sleeve your block with Benson Sleeves (From Laskey Racing), Go CP 9:1 pistons 83mm, Pauter Rods, LS Crank, and Benson balanced crank, ITR oil and water pumps that setup will handle 30psi for years
Old Jul 14, 2006 | 07:13 AM
gsr336's Avatar
so how much money am i looking at? and where can i find these people yah are talking about?
Old Jul 14, 2006 | 07:17 AM
DaveF's Avatar
http://www.laskeyracing.com
but since you are in NC. why not RLZ ?
Old Jul 14, 2006 | 07:28 AM
gsr336's Avatar
Default Re: b18c1 block (dturbocivic)
rlz?
Old Jul 14, 2006 | 07:31 AM
DaveF's Avatar
RLZ engineering.
http://www.hondaraceengines.com
Want horse power from your Head ?
Call me 704 262-7948
RLZENGINEering
313 Manor Ave
Concord ,NC 28025
Old Jul 14, 2006 | 07:41 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
but since you are in NC. why not RLZ ? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">RLZ engineering.
RLZENGINEering
313 Manor Ave
Concord ,NC 28025
You can contact Howard the owner of RLZ on here his screename is airshifter or email him is also good speedinnovations@ctc.net , it is hard to get ahold of them by phone a lot because there are two people there, Brad Z ports heads all day everyday and Howard builds motors and tunes. Email or PM or do both and you will hear back from them. They currently have my block and head and doing my build up, in the mean time I just have a shakedown motor installed until they work their magic. I made 90whp on low boost just from their ported head and made 60whp on high boost just from the head swap Tell them Terry aka Boostfed sent you too
Edit:Also don't start the block off at 85mm!!!! If you need to rebuild it you have no room then for FI, you then have a block for NA! Start at 83mm or even 84mm that way if you have an issue you can overbore later. You won't see a huge difference from 84mm to 85mm anyways, READ I said not a huge difference.
Modified by Boostfed.com at 12:24 PM 7/14/2006
80 dolla crx hf
Apr 28, 2009 02:09 PM
joedeezy
Oct 26, 2008 11:51 PM
ge_itr
Jan 8, 2007 09:37 AM
calizum
May 24, 2005 09:36 PM
Morhpeous
Jul 29, 2004 07:38 AM
